LC Crystal Oscillator - UK/Europe
Hello!
I recently picked up an LC, and unfortunately, there is serious corrosion on the board becasue of a leaking battery.
I have cleaned this up as best I can, but some components are in need of replacement. Aside from the caps, I specifically need to replace the 31.3344 Mhz crystal. This looked to be completely destroyed.
I have had no joy whatsoever finding one of these online, save for from the US, with naturally high postage/shipping fees to the UK.
Does anyone have any idea where I could source one of these?
31.3344mhz oscillators are impossible to get in the UK (I have searched for ages!) but you should be able to substitute it for a 32MHZ one which are still easy to get. I haven't tested this yet but there isn't any reason I can see it shouldn't work
Looking at the board you are likely going to need new ROM's and sockets and I would expect you have some trace damage too but it's hard tell from the pictures. The ROM's can be recreated using 27C010's if you have the appropriate programmer
BTW, I have made reproduction PCB's for this model (https://68kmla.org/bb/index.php?threads/reverse-engineering-the-macintosh-lc-logicboard.38495/) so if your board ends up being unrepairable there is always the option of replaceing the entire PCB :) (You do need to be able to unsolder and resolder all the customs IC's though)
Would these be what you need?... View attachment 36194
Thats the ones!
I was going to order some from the US but the ebay seller that has them didn't have the large lots in stock anymore, but it seems they have the lots of 40 back in stock so I might just order myself a batch from there
I have also ordered some 32mhz ones form RS but haven't had a chance to try one yet
Well... I ordered 25... which are coming back with me next week. I don't need any, but figured it'd be worth bagging some and bringing them back... along with all the other goodies! 😀 I thought you might like to take them off my hands. 8-)
Well... I ordered 25... which are coming back with me next week. I don't need any, but figured it'd be worth bagging some and bringing them back... along with all the other goodies! 😀 I thought you might like to take them off my hands. :cool:
Oh cool, i'll happily take those off your hands :)
