Raccaped LC II, no shime, no sound, no video ...deadend?
Hi everyone,
I have an LC II, apparently in good shape — no battery damage, it was stored in a warm, dry place, and there’s no visible corrosion.
The absence of the J9 IC seems to be normal in these boards.
Pin 117 of the CPU is bent, but there is continuity.
However, the capacitors near the EGRET and sound section had leaked slightly.
I removed all of them and cleaned the board in the dishwasher (without soap).
After that, I dipped that corner of the logic board in an ultrasonic cleaner — which, in hindsight, was probably not a good idea.
I then replaced all capacitors, checking continuity on every solder joint, pad, via, and trace.
I also cleaned and rinsed the board again thoroughly with isopropyl alcohol.
The PSU has been recapped; voltage rails are stable and verified on another working LC.
A new PRAM battery was installed — and at this point, it should have been an easy success story
But at boot: no sound, no chime, no video.
Same behaviour with or without RAM. I didn’t bother checking VRAM because the startup chime should sound regardless.
The CPU gets warm, but all other ICs remain cold.
On the first couple of power-ups, the speaker produced some crackling noises, then went completely silent.
Using an oscilloscope, I probed Y1 near the EGRET and saw a 32 kHz sine wave, which seems correct — though I’m new to oscilloscopes, so I might be my clumsiness.
At the CPU’s CLK pin, I see a 15 MHz signal, but it looks sinusoidal instead of square. The probe and scope are both set to 10×, and the ground is connected to the chassis — but again, it might just be me. I don't understand the voltage reading; it seems too high to me.
At this point, I’m not sure how to proceed.
I could try replacing the EGRET or the DFAC blindly (assuming I can find the replacements), attempt serial debugging as shown by Adrian, or accept that this logic board may be a dead end.
These are nice looking new caps - good job replacing them! I find it hard to hold them perfectly aligned. FWIW, I posted lately on 475 revival, where the crucial thing was a vinegar bath. This removed some of the oxidized material from the vicinity of leaking capacitors, and made a break in one trace (on the other side of the board!) finally apparent. My symptoms were a bit different - chime but no boot - but who knows.
@MBehr thanks — it took a couple of years of practice :) I believe my issue is more on the hardware side, but I'll check on the other side
@cheesestraws mate, I checked the specs and found that pin 15 is the RESET OUT from the EGRET.
I added a push button at S1 on the logic board (which connects to pin 1 + GND, the HW RESET of the EGRET) so I could monitor the signals without having to power-cycle the PSU.
It seems, however, that pin 15 doesn’t switch or move at all during reset.
So... can I conclude that I fried the EGRET with the ultrasonic cleaner? It might have already been bad, but I doubt it.
There’s also a GitHub project related to this, but the build stages and instructions aren’t clear to me.
It’s also unclear which Mac models the EGRET can be swapped into — I have a few damaged logic boards lying around.
