The lack of auto-mounting is probably that INQUIRY thing: as I recall the current version may not be spec-compliant. I added an issue on Github to remind me to review it.
There is a buffer on the debugging USART, and as long as it doesn't saturate it should only be a ~150ns hit each symbol. I've also found the performance hit to be minimal. On the other hand, parity does slow things down: I think I found it was ~33% worse, at least the last time I checked. That part of the code could use some optimizing.
