Any SCSI experts? Need help getting a SCSI scanner to connect to G4.
Apologies if you are seeing this post in multiple forums. I'm cross posting in a few places since I'm looking for some very niche expertise:
Any SCSI experts around that can try and help me out?
What I'm trying to do is connect a Minolta Dimage Scan Elite F2900 film scanner to a G4 Powermac and use it in OS 9.2.2. So far I have what I think is a working scanner, and a working SCSI PCI card but can't get the scanner to show up.
The scanner has a Centronics, aka SCSI-1, aka CN-50 port and a DB25 Port. It has dip switches for selecting the SCSI ID and turning on/off the internal terminator.
I purchased a ATTO UL3D SCSI PCI card that had previously been used in a Powermac, so it should have the correct firmware. In OS9's system profile I can see it as a SCSI card with v. 1.66 firmware, which is the latest firmware I can find. I selected this card because it is one that is supposed to work in both OS9 and OSX. It's product manual says that it is compatible with SCSI-3, SCSI-2 and SCSI-1 devices and backward compatible with Ultra2, Ultra/WIDE, Fast/WIDE and Narrow SCSI devices
The ATTO UL3D uses a much more recent SCSI connector than the scanner. It's a VHDCI, aka SCSI-5. So I purchased a VHDCI to CN-50 cable from IEC.net, the only company that seemed to actually have such a cable in-stock (or maybe made on demand).
With everything connected up, I boot up the scanner before turning on the Mac. OS9 is slower to boot now which makes me think the SCSI card is looking for devices. However I see no new SCSI devices in the system profiler.
I downloaded ATTO Express Tools 2.82 from the Macintosh Garden. It shows my SCSI card but doesn't show anything for any of the SCSI IDs. It's like the scanner isn't there. The photoshop plug-in and the scanner software that came with the scanner also act like its not connected. I've tried a couple different SCSI IDs on the scanner.
The scanner was new-old-stock and looks brand new. It turns on and makes the lights and whirring sounds I would expect from it.
I'm not sure what else to try. Maybe:
-Trying the SCSI card in other PCI slots?
-Getting a completely different SCSI card even though the one I have should be backwards compatible? The manual for the Scanner recommends the Adaptec PowerDomain 2940UW, PowerDomain 2940U2W, PowerDomain 2930U, or SCSI Card 2906.
-Trying a different cable, like going from CN50 to SCS-2 and then to VHDCI. Or finding a chain of cables to connect to the DB25 port instead of the CN50 port.
Is there any secret SCSI sauce that I'm missing here?
My boot disc is running off a PCI card based SATA controller with an SSD, which presents itself as SCSI in OS9. I don't know if this could somehow be getting in the way of a "real" SCSI card?
I'm 100% brand new to SCSI. I started with macs right as OS9 was transitioning to OSX so I have always been spoiled by how USB and FireWire "Just Works."
You can get a terminator for the DB25 port and not use the internal terminator.
USE ID 2,4,5 OR 6 for the scanner SCSI ID.
Most likely you just have terminator issues. You will need software/drivers for the film scanner (which you have).
Thanks for the advice. I have tried SCSI ID 5 and 1. 5 was the scanner's default. I knew to avoid 0 and 7 but will also try 2 and 4.
I thought both the card and scanner provided internal termination but this is all new to me. I'll order a DB25 terminator to try. In that case I would turn off the scanner's internal terminator using the dip switches, right? Do I need to do any termination on the SCSI card side? It has 2 internal and 2 external ports.
What is the difference between active and passive terminators? Do I need one vs the other?
The scanner has a built-in terminator power switch. The Scanner's manual says that if the scanner is the last or only device in the SCSI chain to turn the switch ON and that "an external terminator is not necessary with this scanner."
Termination on 8 bit and 16 bit is a bit different.
8-bit termination is usually passive (just a bunch of resisters) but can be active (uses a bunch of voltage regulators). 8-bit termination works on 8 data lines plus 1 parity, 16 bit termination works on 16 data lines and 2 parity. So using an 8 bit terminator on a 16 bit line will only terminate half the data lines causing the card to have issues.
On PC cards when the machine boots up you get a list of devices connected, their ID, and their bit 8 or 16, mac cards don't show that stuff while booting so they are harder to figure out. I don't know if you have a PC with PCI slots, but that ATTO card should have dual PC/Mac BIOS so you can connect it as is to the PC and see what shows up if anything on boot. The UL3D SHOULD auto terminate the top 8 bit lines for 8 bit SCSI (to be compatible with older devices) leaving you to deal with the lower 8 bit lines.
My only guess is that since you used active termination on the scanner the SCSI card figured its a 16 bit device and didn't terminate the 8 other lanes causing problems with noise (which would make scanning for SCSI ID's take a lot longer). A passive terminator should fix that problem as long as the cables you have are not damaged or anything.
Seems like I found the SCSI guru! Thanks for all this info. Once I get the DB25 terminator in I'll give it all a try with the terminator dip switch on the scanner turned on and off to see if either works.
If that doesn't fix it, my next step may be trying to source one of the period correct Adaptec cards that the scanner manual recommends.
Unfortunately I don't have a PC to help
I received the passive DB25 terminator that I bought from eBay that looks exactly like the one in the photo you posted. Still no luck getting the scanner to show up. I tried with the internal scanner termination on and with it off. I tried with SCSI ID's 4 and 5.
One weird thing is that none of the settings "stick" in the OS9 ATTO Express Tools software. Every time I rescan the SCSI busses or restart the computer, any changes I have made to the configuration revert back to default. So I'm not 100% sure the SCSI card is working as intended. For example, in the software it gives the option to turn automatic termination to off, lower 8-bits, full, or automatic. The default is automatic. If I change it to full and then rescan the SCSI busses to see if it helps, the setting resets back to automatic.
I'm going to try finding a different SCSI PCI card from the list of suggested SCSI cards in the scanner manual.
I made a little more progress yesterday. I was able to find a download for ConfigTool version 3.38, which was designed for OSX 10.4 and 10.5. It was able to see my ATTO SCSI card and both busses and it DOES let me change the cards settings. For example, I was able to set the Termination setting from Auto to Full and then when I booted into OS9 the ATTO Express Tool app there showed the settings had been preserved.
The scanner is still not showing up though. I set termination to full on the ATTO card set the scanner's termination dip switch on.
There are a bunch more settings in ConfigTool I could play with but I don't understand what they do. Do you have any recommendations for these settings?: Selection Timeout (ms), PCI burst rate (bytes), Wide ID (enabled or disabled), Fallback Sync Rate (MB/s), Specific Target, LUNs, Allow Disconnect, Tag Command Queuing, Sync Enabled for this ID, Sync Offset.
I do still have a different SCSI card and cable coming in the mail later this week. I'll be able to try that soon for some additional troubleshooting.
I would suggest finding an external SCSI CDROM/CDRW/HD etc. to see if your card and cable work. For all you know that scanner could be toast.
I got it working! But not with the ATTO card. An Adaptec SCSI card 2906 with a DV25 to Centronics 50 pin SCSI-1 cable is what worked.
The downsides are that the card slower than the ATTO card when used with compatible SCSI devices. The Adaptec card might also be OS9-only since it relies on OS9 extensions to run. I still need to try it in OSX to confirm.
The Adaptec SCSI card is fine for now because it matches the specs of the scanner (10 MB/second SCSI 2 and OS9 only). I might keep messing with the ATTO card in the future to be able to use SCSI under OSX but for now I have a usable workflow.
I'm not sure why the ATTO setup didn't work. It could have been the card hardware, the card's firmware, the software/drivers I was using, or maybe the cable I was using although the cable was brand-new.
