Isn't it amazing how things never *just clear* the possible obstruction by a quarter millimeter, it's always the reverse?I then did a test fit in the machine and... the board fouls the next socket along by about 0.25mm!
What program do you use to make that sort of thing?wholy shit that was fast. I wish my chinese PCB supplier was that fast.
Im still waiting to hear back on a quote from days ago.
Oh, and BTW, I dont use the autorouter. I always layout PCBs manually. seems to work better for me.
For example, this was my latest design:
Is there any possibility of shortening the pins on that connector? I can't clearly see how they're constructed, are the uprights thicker metal with the smaller solderable pin set inside the end, or is there an insulator around a contact that's all around the upright pin that at least in theory could be trimmed back to let the board sit lower? Or, heck, it'd be a huge PITA, but how about filing the pins down if they *are* metal?
Edit: I guess they're turned metal. I'm sure filing them down would be amazing fun.
Here's a Winslow catalog, it at least *looks* like they make that adapter in different heights. What suffix did you buy?
https://www.winslowadaptics.com/app/uploads/2019/03/PLCC-plugs-I5.pdf
I actually had to file the pins down on a right-angle ISA slot connector I bought once to fit it into a board that had too-small holes once and that was *not* fun, and in that case the size mismatch was a lot less so, yeah, it'd be really hard. Only chance would be a motorized sanding wheel and one slip, bang, you've killed it.As for the pins, they are very fine, 0.49mm so it's not really feasible to modify them after manufacture. (They are metal, looks like gold coated.)
The "Freerouting" auto routing work-around works fine. It needs a bit of time and sometimes it gets stuck. Just moving a component by a 0.1mm in the design and suddenly it works again.For us mere mortals there's Kicad. It's... totally okay, really!
(When I first started using it I really wished it had a functioning autorouter but, hey, routing by hand is an interesting puzzle challenge.)
I actually looked into it after you mentioned it, and my eyes totally glazed over between it needing that manual export stage and it requiring a Java runtime to execute.The "Freerouting" auto routing work-around works fine. It needs a bit of time and sometimes it gets stuck. Just moving a component by a 0.1mm in the design and suddenly it works again.
