Yet another SE/30 Restoration Project
So, my Macintosh SE/30 arrived yesterday. :)
Ain't she a beauty?
BUT..................!
Yep, as expected, the battery wreaked havoc on the PCB.
And so the journey of restoring this, otherwise beautiful machine, begins. ;)
Interestingly, this SE/30 also had a third party graphics card installed:
"Formac ProGraph"
Has 128K of VRAM, 45MHz oscillator, standard TMS34061 graphics controller. Probably a high resolution monochrome card. Did not find any information online about this, yet. The card seems to have been made in 1989, so relatively close to the release of the SE/30.
But we'll come back to this later once I get this machine to boot again. :)
So what's next?
  • Ordered Bolle's replacement PCB (thanks @Bolle for your great work!)
  • Yesterday night, ordered one huge batch of components from mouser
  • Started to source the standard components (SCC, SCSI, VIA, etc...) which are still available NOS
  • The corrosion seems not to have affected any Apple specific custom chips - so I will desolder them, put sockets on the new board where there are any apple specific custom chips, and see how far I can get here
  • Testing of the power supply
I'm also trying to salvage specific things, like the 68030 CPU, the Video Rom and the original PALs, in case they still work. If not, I'm going to replace them with Bolle's GAL recreations. The 68882FPU is too much corroded - trying to get a genuine 16MHz Motorola part.
Good call on the FPU, that was right where my eyes went... After staring at the off-axis resistor pack with its legs eaten off. I'm a relative newcomer to this level of rework, but the Reloaded board is surprisingly manageable in terms of complexity, so for you it should be a piece of cake.
Reading build logs and seeing what people wished they'd done differently (i.e. "I should have installed UH7 before any other component in the middle!") helped me a lot, personally. I have never seen an SE/30 board, not even a later revision one with a soldered CPU and no /NUBUS bodge, where the PAL DIPs for the built-in video were all directly soldered like that.
Thats a pretty good looking donor board. I'd bet you can save everything on it (even the fpu). I'd replace the 258's and the 161's just for peace of mind. A new rom socket, a processor socket, new caps, and Bob's your uncle!
The caveat being... it's a lot easier to use new parts since the main time hog is recovery and prep of the used parts. Plus you know the new parts work (most of the time - may fake chip makers burn in the hell of molten silicon).
If building a reloaded board, be aware that the traditional replacement RAM slots from PE connectors have shot up in price and are now $40 each! Used to be like $6.
So take care desoldering the existing ones.
Thanks for all the tips, just waiting for all the parts to arrive. I'll be also recapping the power supply and analogue board.
Due to the problematic weather conditions in the US, shipments from Mouser are currently very slow.
The most difficult aspect will be to find out if GLUE, or any other important chip is still working.
And if not, well, seems then that I have a reason to design a full replacement board myself. ;) Because the exterior of this SE/30 looks great, it deserves to be revived!
For what it's worth I've never yet found a dead GLUE. The clocks coming from it should be easy places to start... Assuming you own a proper scope already, unlike when I first tried. Reaching a RAM-less death chime at all is usually cause for celebration.
Update:
All of the important parts, and most of the lesser ones successfully salvaged.
Now waiting for the PCB and the new parts.
These are coming as NOS parts. ;)
What was important for me to salvage were things like the white mini DIN connectors, matching the case color. Nowadays, you can only get black ones, which work, but alter the original look.
Update, mainboard is coming together now…
And my DoubleVision SE/30 graphics card is already fitting perfectly, waiting to be developed on this configuration. ;)
