Source code is already up, so you can manufacture your own. https://github.com/saybur/scuznetHave you made any more progress on this? This is a really great idea, and there are a ton of machines lacking easy access to Ethernet.
- Alex
Have you measured current consumption while idle and active? What's up with the dual-linear-regulator design? Seems odd, am I missing something?If anyone has questions or comments, please fire away. Thanks for reading!
Source code is up, so you can start manufacturing your own now. https://github.com/saybur/scuznetSo admittedly, I haven't read through this entire thread... but I just wanted to say WELL DONE! There is a huge need for this kind of hardware, I'm thrilled that you took on the task and figured it out. Amazing work. 10/10 am interested in getting a hot air station so I can do SMD work to make some of these.
I'll be following the thread closely!
Definitely would.I have a batch of Printed Circuit Boards on the way, if anyone would like one.
One is 2.63V for the terminator, and the other is 3.3V for everything else. These could probably be switching regulators rather than big old linears, but I'm not familiar with switching regulator design and I didn't want to mess with that as part of the project. The weird 2.63V voltage is used instead of the standard 2.85V on the terminator due to Digikey not stocking 110ohm 10-SIP bussed resistors, so I went with an alternate configuration using a lower voltage and more common 100ohm parts (this is supported as part of the spec, though I've never seen a device using it in the wild). It would be trivial to replace the two regulator adjust resistors and move to the standard 110ohm resistor packs if desired.Have you measured current consumption while idle and active? What's up with the dual-linear-regulator design? Seems odd, am I missing something?
Power consumption has not been measured, but it likely isn't all that high: figure ~100mA for the SD card, 180mA for Ethernet, and ~480mA for the terminator as the main power sinks. Keeping with the KISS philosophy on the power side, the regulators are oversized and have pads for extra heatsinks in case that was necessary, but during testing they barely got warmer than ambient air while outside the case.
If a reference would be of interest, I've added the BOM I used when making my boards to Github. That should more or less be accurate: I dropped the unnecessary 128A3U XMEGA part down to 64A3U, as the extra memories are not necessary for the firmware.
The PCBs are finally out for delivery today via DHL. I'll keep y'all updated.Definitely would.
Let me guess... delayed by Chinese New Year and Coronavirus? I did a run of PCB's for a conference badge a few weeks ago, and at the last minute I had to do an emergency order from a Korean PCB manufacturer because my order from JLCPCB so delayed. It sounds like a lot of people have been affected by this.The PCBs are finally out for delivery today via DHL. I'll keep y'all updated.
That’s surprising, since I recently got an order from JLCPCB and they told me they weren’t experiencing any interruptions due to Coronavirus.Let me guess... delayed by Chinese New Year and Coronavirus? I did a run of PCB's for a conference badge a few weeks ago, and at the last minute I had to do an emergency order from a Korean PCB manufacturer because my order from JLCPCB so delayed. It sounds like a lot of people have been affected by this.
Looking forward to seeing how they turn out!
They're here, and rather than hijack this one further, I've started a new thread for it here. I'll be selling them with parts kitsLooking forward to seeing how they turn out!
