still not there with this tam
Did a recap of the motherboard and it is still the same - bad display, no sound, no control from front panel and harddrive wont spin up
ive checked all the caps to make sure they are all right but the tam is exactly the same as it was before the recap
to be honest I don't think it needed the recap yet - but sure anyway its done
have gone over the machine time and time again but I am at a loss as to the problem
I am trying to power it on with just 1 ram simm, no cache and no rom simm
going over the motherboard with a magnifying glass I discovered that C113 is missing. It was located directly under the battery and looks like it was an acid victim
I have no way of knowing what its value was or how important it was.
You can still see green on the traces under where the battery was
however when I turn it on even though the display is all messed up, after 10 seconds I get the flashing disc icon....that means that much of the board must be good. It boots from a floppy but stops during boot and gives an error - probally wrong system on the floppy - I can use the mouse, even though the screen is all messed up, to eject the floppy
is there and schematics of the tam? - how would I get the value of c113?
dam acid leaks!!!! - starting to wonder if it is indeed too late for this board. Also it stops powering up after 5 or 6 powerups. You have to disconnect it for 20 min before it will start again
man this thing has truly wrecked my head. Tam = lovely machine to look at but a devil to work on. Just opening that powersupply took a whole day
