TAM
just tried to power it up ........no joy
zip!!
tried it with / without rom and cache card....nothing
im flying blind here people.............how do I turn it on!!!!!!!!!
I have no pram battery installed. I found the power button on the rear, left hand side, next to the main cable from the subwoffer
I see no activity of any kind, no led's, no sounds.............
what is the correct start up procedure.............hit the power button on the rear and then hit the top right key on keyboard
mmmmmmmmmmm...................will it even start without a pram battery at all??
I didn't bother connecting the cd drive , the hard drive or the network card ......im pretty sure ive connected everything else
should there be an led on somewhere to show life...anything.............it is as dead as my hairline!
heelllppppp
found a similar battery from a lciii or something - same connector
tired it....still nothing
caps don't look good...........many have an upwards pointing dimple in the top...........
can I test the subwoffer for power on that big round connector?.....surely there would be 5 ,7 or 12 volts coming from it ?
Doesn't need a PRAM battery to work/start. You can just press the power button on the back of the unit OR on the keyboard.
There is a CUDA reset button on the board you should press before you try to start it up. Sounds like it has a cap issue which might be the culprit.
just metered out the subwoofer cable and nothing -
should there be some signal coming from the powersupply to the machine ?
ive tried the reset and nothing
think ill just do a full recap before anything else
later
I never got around to re-capping mine yet. You might be the first to re-cap one if you do.
I would check the power supply first, its fuse, etc...
By the way, the power supply is not auto-switching. Maybe I missed where you said you checked it, but if not check it.
edit: There should be 5v standby power from the supply I would think. I can check mine later if needed.
hi unity. Yep I made sure its on 230 volts - the guy I bought it from told me about that as well.
ive opened up the subwoffer.......dam difficult......its held together with screws and double sided sticky tape
the sticky tape is all around top rubber and all the inside is lined with some other soft tape - avoid rattels from the bass I guess.
it looks like a standard power supply with a audio amp board on the side.
this subwoffer was dropped at some stage of its life. There is a 2 inch crack in the plastic cover on one side, and as I began to open it 2 of the screws turned, but the plastic they were screwed into was broken off inside and was turning with the screw.
I got it open without any futher damage.
there is no sound from the power supply of any kind when I plug it in. usually there is a quit hum or something. I know the thing is in sleep mode waiting for the computer to switch it on......bit this thing looks dead to me
there must be a fuse inside that power supply, and seems it has obviously had a knock... im thinking the fuse has been dislodged
heres a few pics
whats your thoughts people
took out the powersupply and the bose audio board
not really much to it - looks like a standard powersupply with a output to plug in your monitor
ha ha ......caught ya apple... hiding power ports!!!    be jasus
gonna open the powersupply to see if there is a loose or blown fuse
finally got into the powersupply - was covered with some foamy tape crap - had to cut through it
but anyway............found the fuse....6.3 amp   250 volt
and its dead!!!!!!!!!!!!
great stuff
in with a good one and slap this thing back together!!!
found a 250volt 8amp fuse in my external scsi.........that would be ok yeh?
Good finding - no, I'd match the fuse with same.  Note there is a green LED on the underside of the sub that'll tell you if powered
just had an explosion from the power supply......holy %^^%$£
8 amp fuse ...black and dead.
a few caps black and dead
at least I didn't have the tam plugged into it
new plan.......new power supply......ive blown the hell out of the old one
just checked and there are simmilar powersupplys on ebay.....but with different wiring
seems I have this blown powersupply with the correct wiring......I could just get a new one and move over the wiring
heres a link to one for sale
http://www.ebay.ie/itm/Delta-Electronics-DPS-150GB-A-Apple-614-0039-150W-Power-Supply-150-Watt-/141661288905?pt=LH_DefaultDomain_0&hash=item20fbabb9c9
different apms........
dam it!!!!!!!!
YIKES! Good luck man. I've got some of those PSU's out to be looked at and they are pretty special. Let me know what you can do with a swap as I might need that here at some point.
people..............im depressed
im gonna talk to the lepracauns.......................
as father jack would say........FECK!!!!
Well, Usually when a fuse blows. 90% of the time that doesnt mean stick a new one in it and try again.
they blow for a reason. Well, now you found out the hard way. Think twice!
Most likely had a shorted FET, or bridge or something. coulda found it before swapping the fuse.
In my opinion, the Power supply is a modified 6500 unit.
I was given a Powermac 6500 and only kept the Logic board, wiring and PSU because they all were close to the TAM's one.
I think  the plug and wiring from the PSU should be the only difference.
Damn! Sorry to hear that. As technight said there is a reason. I am just surprised the fuse did not simply blow again.
