TAM
gave it a good wash - vinegar/water 50/50, then the usual water and washing up liquid
it looks allot better
there is still some green , but allot of the via's that were all green now show some shiny solder
will have to leave it till tomorrow -
heres hoping!
Focus on that rom slot and it might work, you might not even need that rom since the 6500 doesn't but I'm not sure...
Don't understand why it would work without the rom!!!
Does it have another onboard?
off to bed for me
sure I had to film the teardown
good luck people
I know where you can get TAM boards. They aren't cheap but they are available.
Hey hap,
is that from that place in the Netherlands?  I've been keenly looking for a CS slot riser card for years, but even he doesn't have them.  If you ever come across one, please let me know.
Nice score falen5 - I wouldn't go too overboard with the cleaning (and let it dry for a few days in a sunny location, not just one), or worry about caps.  Hoping you will get more life out of it.  You should also check the sub/PSU cord for any damage, and do a multimeter check to check power is actually getting through :)   The 6500 board could be modified to fit, once you desolder some connectors and I'm betting the TAM's sound PCB is a straight drop in once soldered.  Then all you are missing is the startup chime, but since the 6500 and TAM ROM are exactly the same, I'm betting it's a resistor placement on the board that sets the unique TAM startup chime.
Also, just as a minor point on the chemistry, if vinegar neutralizes it, then its an alkaline substances eating the board, not an acid, you can't neutralize an acid with an acid (at least not in the purest sense of the phrasing)
off to bed for me
good luck people
yes, it does have two on board roms:
These two guys are what the 6500 uses to boot so I'm thinking it might work without that rom simm...
There is no ROM SIMM for the TAM, never was unless proto.
Good theory on the ROM with startup chime. I can not say, but falen5 I think has the skills to swap ROM chips if needed.
It's not a rom simm , it should be cache card, which with a G3 upgrade should be removed. Maybe that's why it was put away and didn't work in the first place.
Rom simm and cache cards use the same slot on those boards. In fact my 6500 says rom/cache slot.
how we doing people - finally got home to have a go at starting this thing up
as for the rom's etc etc ....heres a few snaps of the board.
Ive never had a tam before so I make no claims. But the board says rom , cache, and drams - I don't know!
anyway will try to put it together and see what happens. If it powers up ill try it with and without the rom.....just to see if there is a difference.
all I can think is that there must be some reason apple put a separate rom in this
oh...the guy I bought it from in Dublin told me that he bought it while over in the states, and was so impressed with the sound he shipped it back home to Ireland. So its a  TAM from America and not a European version. Best find in ages...I bought the TAM and the classic 2 from him for 200 euro - weh hey!
The part number shows its a G3 ROM? I wonder if someone thought it was or is needed for the upgrade card? I never heard of that if so. And like I said, the TAM never shipped with its own ROM card.
Check to make sure the Bose unit has the appropriate power voltage selected. Sounds like it probably does but always good to check. Keep us posted and my fingers are crossed for you.
first thing I checked haplain..............don't want any explosions
still some 'green' on the main board - my eyes are going bad...quickly...I only see the green in the pictures.
will give the board a wash in acetone, dry it out, and plug it in
fingers crossed
And the plot thickens... The funny thing is that the 6500 board has the pads for the rom but not the socket?
Ya, the 5500 & 6500 are the same board as the TAM, just with modifications. My guess for the TAM having the ROM slot installed is given the unique nature of the machine. Its pretty common for Macs, even the PowerPCs, to have a ROM slot but no ROM intended for it. Being what the TAM was, it may have been a safety net thing.
Nearly all of my TAM's which is a gaggle at this point, came with the chip but I don't have them in. They work without any issues. Given the corrosion, I wouldn't install it as it could cause more issues than doing anything positive.
