Jump to content
Force 10 mbps on 10/100 hub with Cat3 cable?
Recommended Posts
Hi All,
I have an Asante NuBus card discussed here that does not play nicely with the 2 D Link 10/100 hubs that I have.  These hubs work fine with my Asante IIsi/SE/30 cards. To get the Nubus card recognized I need to short the pins on the card after boot sequence has started. The Nubus card works fine (w/o shorting the pins) when attached to an old Hawking Tech wifi router. I don't like this hardware as it has no way to disable its old wifi.
While I could get a hub like this Netgear EN104TP I am wondering if this could be solved with the ethernet cable. All I have is Cat5 or Cat5e cables.  If I were get a Cat3 cable, would that force the D Link hubs to 10 mbps? I Googled a bit yesterday but could not find the answer. Does anyone know?
THx!
Link to post
Share on other sites
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
