Jump to content
Trash80toHP_Mini
E-Machines Big Picture Card w/Mac SE Interconnect
Recommended Posts
I've suddenly got another oddball SE VidCard to mess with on the bench. The SE Adapter board is what got me, what else did they use this thing in? It's a two row subset of the SE PDS, which doesn't mean much because there's not a whole lot going on in the center row of the SE's 68000 PDS. I'm wondering if they made 030 PDS Adapters for ithis card? Lots of research in the MacUser archive coming up.
The signal listing on the breakout cable connector was the other thing that got me. IIRC these cards supported two resolutions depending upon which of the two monitors it was driving.
The PTO is curious as well as the IC on the adapter. Having PAL logic on there is the third thing that got me. Is it the missing logical link between the 68000 and 68030 PDS implementations? :huh:
Anybody seen drivers for this puppy anywhere online?
Edited by Trash80toHP_Mini
Share this post
Link to post
Share on other sites
I haven't spotted a date on the VidCard itself yet, but there are only a few reasons for that PDS adapter that I can think of offhand.
- the card may have had a Mac Plus/68000/Killy Klip type adapter adapter
- the card may have been designed for use with a 68000 Compact Mac accelerator, which might explain keeping the profile low via the double header interface.
- - - Compacts were single bit video, which means that a lot of address
- The form factor suggests the a NuBus adapter would be physically incompatible and IIRC they made a NuBus card for those monitors, which would have been grayscale.
The only Mac with a PDS interface in 1987 was the SE, but E-Machines may have been seeded an SE/30 prototype. It was released January, 1988.
I don't really care if the adapter's PAL logic translates 68000 <-> SE PDS or SE PDS t<-> 68030 PDS, either one makes it a significant find for back at the Skunkworks.
It should be here Saturday, looking forward to buzzing it out.
Share this post
Link to post
oooo if you ever want to part with that card let me know. That card will actually connect to a passthrough on my GCC Hypercharger 020 card in my Mac SE, similar to what Radius cards did on their Accelerator upgrades. Hooks into the "64 pin header" connector on the card.
Here's a snippet from an old review that mentions that.
And the card itself:
Edited by Compgeke
Share this post
Link to post
Might could be if I can get the Radius TPD up and running in my SE. So the PAL translates 68020 speak to 68000 speak? Not exactly what I was hoping for, but useful. I bought it for the adapter, but useful nonetheless. If you can buzz the connections from that header to the rest of the accelerator, post the results here and make me an offer. [;)]
Share this post
Link to post
I've been meaning to buzz it out out of curiosity to know if a Radius FPD card can be made to run off the back. I've got a full FPD setup here, but no Radius accelerator card. Just the Magicbus card. One of these years I'll get around to doing just that. I dream of the day I have a Dual Superdrive w/ HDD + 68020 + FPD Mac SE. Maybe promptly blow up the power supply but we'll know when we get there.
Share this post
Link to post
I was going to say that there are 64 pin connectors on CPU upgrades and that the card plugs in there.
The PAL looks like it's just an address decoder. One of the outputs goes to /EXT.DTK which tristates the /DTACK on the logicboard.
This would normally be handled by the accelerator.
Share this post
Link to post
oooooooo That was my dream setup for a good couple of years. I had the Radius 16 and wanted the FPD SO badly! Wound up with a IIx and a Panasonic TPD/Card combo (also 1-bit B&W) with plans to get the Rocket. Worked out fine, but never did get that FPD. Tried once on eBay, but the seller wouldn't let me pick it up, insisting on getting ridiculous S&H fees. :P Got pics of your FPD with the lights on?
Now I've got the Radius 16 in an SE again and a Radius PrecisionView 2150. So I picked up a couple of TPD cards, no joy yet, but I'll get one up and running some day. Way too many projects, way too little time and attention span. ::)
Share this post
Link to post
I ended up getting mine for $50 from a guy out of San Francisco. Close enough shipping was only $35 on it.  Got plenty of pics, https://imgur.com/a/yIu5y . The thing is way overbuilt. The front panel is entirely cast metal with the CRT screwed into that. The rest is all secured into a metal chassis with the only plastic being the back case bucket and the stand.
Share this post
Link to post
Nice! On my way to pick up the VidCard and CC/LC ThunderCache Accelerator, I realized that the 68020 to 68000 adapter may be just what the doctor ordered. Couldn't hardly be better, it's a two layer translucent PCB so I can see both sides of every trace from either side of the board! [:D]
439121017_ThunderCache-E-Machines020to68000Adapter-A.thumb.JPG.326476306487a6328c3788f5b79be77b.JPG
MicroMac ThunderCache + E-Machines SE Adapter = PerformerPro +- ???
edit: not as a plug-n-play solution, but in terms of firmware for a new adapter card design with the Pal socketed on adapters old and new.
Share this post
Link to post
Pretty sweet to find a 68020->6800 interconnect adapter that is a translucent PCB. Figuring that out should be a piece of cake.
Share this post
Link to post
So ... I just found one of these eMachines Big Picture cards in my stash of cards, to go along with other Mac SE goodies I've found recently (like the Novy 020 acclerator I couldn't get working).
What resolution does this thing put out?  Anyone know?  And what about drivers?  Have those been discovered?
I'm seriously considering just selling my SE stuff to someone that cares more.  I am way too invested in SE/30 stuff anyways (I think I have 8 of them).  The SE is like the square peg in the round hole at my house.  And not to mention all those pluses I have as well.
- SE case in fair condition (slight chip on rear corner like 1/8", a couple of stickers, and mild yellowing)
- 2 Mobos, one that works and one that needs recap
- Novy 020 card
- eMachines big picture
- Dead Miniscribe HD
So, who's it gonna be? :)
Share this post
Link to post
Hey, I'll take that Big Picture card. It'd be fun to try and make work on the GCC Hypercharger passthrough. Not a lot of information on the card so I bet it won't work on LCDs ,a good multisync CRT maybe.
Share this post
Link to post
Thanks so much for bringing this thread back to life. This adapter/card combo just made it into the LC PDS NIC adaptation project! :approve:
Apparently I can no longer typel ;-/
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
