I’ll clarify, the PaintBoard Li lights up both LEDs as per my photo. That one works with the display as seen as well. The “lines” were due to poor frequency adjustment that I eventually corrected on the LCD itself. I believe the color issue was simply due to my inability to adjust the color via LCD hardware buttons: the color adjustment exists, I believe, in software that isn’t built into 7.1 on my IIfx (the manual says 7.5 or newer is needed to run the monitor).
As for the ColorCard, only one LED was lit; I forget which one now and will have to test again. I could not make my Dell LCD work with it no matter what combination I tried. I tried setting it on 640x480, 67Hz (which is its only output capability) and still nothing. I’ll try more soon.
