I have the Why Cable from JCM-1, because the actual cable is stupid expensive and hard to find.
I'd like to have a short flexy extension cable for the DB-19 connector to the LC card, so there's less stress on the card/connector. I do the same with a DB-15 for the monitor connection hooked up to the Mac Syncinator / VGA Lite.
Anyone know of a place to get one? I found a IDC20 -> DB19 and a female connector that presumably I could use to hack it if I know the pinout, but they're out of stock.
I might just have to hack one together, but I'm hoping someone knows of an existing solution. This might do, but it's a bit fugly, and I might remove the wires from the housing.
