Programmable Diagnostic ROM Idea for Mac "Post Codes"
We've long had reprogrammable ROM SIMMs replacement. Those ROMs often have little improvements, such as skipping memory tests and adding ROM disks.
I wonder whether anyone with experience in developing those ROM boards would consider the following: Add a latch chip with sufficient drive for a small 8-segment or 16-segment LED display. When the Mac writes to the ROM, the bits would light up the various LED segments to provide a "post code" similar to the IBM PC community. Since the ROM is reprogrammable, we could pepper the code with writes to ROM (which would update the display) at various check points as it was booting.
Hopefully, the ROM SEL line is driven low even during writes. If so, one could add address decoding to either select the ROM or the LED latch (which would be placed perhaps at the end 32-bits of ROM space). This would avoid reads to the ROM being written to the latch.
If the ROM SEL line is not driven during writes, then a bodge IC clip would need to be included to attach to the read/write line.
Frankly, even if the ROM SEL line is driven during writes, then a bodge IC clip could be included anyway, and an address decoder would be unnecessary. In that case, the read/write line would control whether the ROM would output, and all writes (to any ROM address) would be placed in the LED latch.
The other cool usage of this would be to aid general hardware/software development. With a "diagnostic ROM" in place, you can display whatever values you want on the LED latch to hunt down bugs or indicate status. For example, if you have a driver where timing is critical or is difficult to debug, a simple write to ROM is all that is necessary to help trace your code.
Any thoughts on the concept?
- David
This would be difficult, sadly. Only the late quadras that support flash ROMs provide a write strobe (and only available under special conditions), unfortunately, and the ROM does not see a consistent select signal across models. Essentially you can only depend on the presence of a single combined OE (read) with implied CS if you want to support all the II and Quadra models. You could do something like a special address range and use spare address lines to encode your byte. Something like if bits A22, A21, A20, A6 set, latch A15-A8, but the ROM space is cachable, you'd need to deal with that too....
For ROM and card driver troubleshooting, I instead took the approach of hijacking a SCC channel and just using that to get bytes out. It's not terribly complex, you can see what I did in the 060 source: https://github.com/ZigZagJoe/Macintosh-Q650-68060/blob/main/src/serial.S I admit it's terribly cushy to be able to blast out entire human readable strings and hex values; the diagnostic variants of my NuCF and 30Video ROMs are quite chatty as it makes debugging so much easier. As the ISP-SIMM has the capability for USB<>Serial, that meant one cable (and device) to upload new ROM images to the system/card under test as well as capture debug info.
I also used capturing the address bus in conjunction with the ROM strobe to gather execution traces since chunks of the ROM map are provided by apple, mostly on the 060 project. This was very useful but of course does require the CPU caches to be inhibited for full accuracy. At one point I briefly used a RP2040 to capture write to a certain slot space and output via serial, but the simplistic implimentation I made didn't have any benefits over serial other than speed and was replaced by serial.
Ahh. That's a problem
What about a 30-pin RAM SIMM + LED latch? Let's say the SIMM is 1 MB and is always put in a specific slot of a specific bank. Although the CAS+RAS+WR+address lines combo are more complicated to decode, you could essentially obtain 8-bits on a write to a specific address. I assume we could locate a byte in low memory that was reserved/unused by Apple. In other words, it is just a standard RAM SIMM that has something that snoops a specific address and copies the data line to an LED latch.
The benefit of this is you'd just use one of the existing custom ROMs that you could code to write to the low memory location as it booted.
If one also burned diagnostic ROMs for non-SIMM computers, a 30-pin RAM SIMM display would also support Plus, SE, and Mac II. A IIfx would instead need a PDS LED snooper, but could use the same custom ROM SIMM.
Nice clean code. I can see how useful this is, particularly for verbose logging. It does require that the stack, SCC, and GLU is working and it does impact timing. However, at that point in booting, it could provide much more intelligent and dynamic messages to the user
- David
Much as I love any reason for more blinkenlights, I think it'd be simpler to interact with test manager over the existing serial mechanism rather than patching the ROM so that every test routine writes a POST code. The interactive test manager mode check happens extremely early, if you can't get into the interactive test manager mode, something's gone so badly wrong you won't get anything useful from the machine's perspective. If the GLU/equivalent and SCC aren't working correctly, your system is fundamentally insane and probably not running code ;)
I was poking at writing some basic routines to run down all the tests and report which failed, but I didn't get too far on it. I recall reading someone else working on a new UI for that recently, can't remember where. My idea would be to stick that on a modern uC (pick your poison) with native USB, add one of the ubiquitious 128x64 OLEDs, RS422 voltage translation, few buttons, and USB back to the host for power/status/serial passthrough/firmware upload.
Put the machine in test mode and interact with it via this magic dongle; default could be on test mode detected, run every possible test for the type of machine expected with a particular ROM and report failures.
This is interesting reading, though it has less bearing on the pre-universal ROMs. https://github.com/elliotnunn/super...MarioProj.1994-02-09/OS/StartMgr/USTStartUp.a
I keep seeing the title of this thread and being confused. In the UK "Post Code" is the equivalent of "Zip Code" in the US.
I'm glad it's not me, although we call it a "Postal Code" which helps me resolve the moment of confusion.
Regional addresses for classic Macs embedded in the PD ROM would definitely be innovative.
On the subject of custom roms, how difficult would it be to give older 68k macs a color happy mac screen like the newer PowerMacs had? I seem to recall my Performa 575 still has a black & white happy mac screen like pretty much all the other 68k machines of it's era. I suppose it could present issues with some machines that used external monitors where the end user could be using a monochrome display but the 5xx series use a built in color screen so it's a safe bet those will always be in color.
Given the Test Manager's propensity to write test results to PRAM, I was wondering idly if that could be hijacked, but that unfortunately gets rather platform specific rather quickly and ends up relying on one having a working Egret in later machines. So that route is probably not one worth pursuing.
Relevant discussion here:
It’s been done on bbraun’s Rom boot disk and BMOW’s Rominator II (a development of the former). Both those give a colour happy Mac/pirate Mac icon on SE/30, IIsi and IIci.
Interesting. So it should be doable on the LC/Performa 5xx roms I imagine. No reason why they wouldn't have in rom Color QuickDraw capability. A shame that forum is no longer around. Would have been nice to ask him about it. :(
Yes. This is genius. Simply latch on address lines 22 + 21 + ROM SEL and use the lowest address lines 2-10 to encode a byte. A write isn't necessary. Skipping around to different addresses in that space would allow the same 2-10 bits to be output without worrying about caching.
this is pretty close to what Acorn did in similar circumstances
Following up on this idea, I’ve put together an experimental diagnostic ROM for the SE/30. I developed it with the help of OpenAI Codex, and I thought I’d share the project in case the source code or documentation might be useful to others.
It includes startup RAM checks, menu-driven diagnostics for several onboard devices, a serial monitor, and an optional Linux boot path.
Source code and documentation:
https://github.com/snua12/se30-diagnostic-rom
Short demo running on a real SE/30:
I’ve also attached a MAME ROM set (macse30.zip). This build uses SCC channel B (printer port) at 9600 baud, 8N1.
Hope this is useful as a reference or starting point for further experimentation.
oh good, first post is slop from someone who hasn't understood the requirements or, apparently, read the first post.
To be fair, having a built-in menu on a diagnostic ROM could be useful; just not really related to the topic at hand (hardware indicators that will trigger early enough in the boot sequence to assist diagnosis). But we've already veered the topic off course a few times.
