Did you actually remove the outer casing of the back/top of the lid(what you see when it is closed), or did you just remove the inner plasticwith the hole for the LCD?Alright, I checked the screw posts and everything seems to be fine, no obvious loose spots, etc. What should I do now about the hinge casing gap? It's not that big, but I'm just a bit worried.
