In the process of rebuilding my PDQ’s battery and found that even with fresh cells I had zero volts at the output terminals. Battery reset program did not make a difference either. I started tracing back and found this odd looking component is open circuit. If I jumper it the battery appears to work great, but ideally I’d like to replace it as its presence near a few resistors called SR1 and SR2 makes me think it is like a 3 wire current shunt resistor.
Any idea what it might be? Part numbers aren’t turning up anything helpful.
