Making a replacement grounding clip from a floppy shutter
I received a Macintosh 128K that was missing several parts (screws, shields, etc) due to whomever opened it last. One specific piece that was missing is a metal clip that goes over the edge of the analog PCB and provides solid grounding contact with the chassis. I believe this is part #805-0576.
It occurred to me that it is approximately the shape and thickness of a floppy disk shutter. Most of us have some spare floppies that won't format anymore. Use one of them, or a virgin System 0.1 disk. Avoid disks with plastic/coated shutters. The grounding clip needs to be electrically conductive on its surface.
For this next step, it helps if you can borrow a grounding clip from another Mac to act as a template. However, the dimensions aren't critical, so you can just rough out a 23 mm x 19 mm rectangle and use the PCB to determine the location of the screw holes.
Get angry with the floppy disk to pop off the shutter. Then use needle-nose flat jaw pliers to bend down the internal protrusions, such as the hook where the spring attached.
Below: Insert a 0.1" thick piece of scrap material to hold the shutter during machining. Not only will this act as a convenient handle, but prevents the sheet metal from deforming. In the image below, note a short cut where I tried to use snips and it really warps the metal. We will not be using this method going forward.
Drill the holes using a 1/8" bit.
Insert screws (with nuts on the opposite side) into the holes to securely hold the clip to the scrap material. This results in a cleaner cut and avoids personal injury from the clip flying off. Apply tape on the portion being removed. Then, using a Dremel with a cut-off wheel, cut along the lines you traced earlier.
Although the shape is now correct, I was disappointed in the scuffing due to my unsteady hand. Perhaps place masking tape over the primary clip portion to protect it? There are also a lot of burrs.
Use a metal file, grinding wheel, or sandpaper to smooth the edges. If I were to cut it again, I would have rounded the corners as well.
Left: Original clip. Right replacement made from floppy shutter. Although not pretty, the replacement ground clip is functional.
I'll be interested in hearing if anyone has a more effective or efficient technique.
- David
Other than the fact that I have some scrap metal out in the garage I'd probably use first, that looks totally fine.
Around here dead floppy disks are saved for art projects. My end goal is an epoxy pour coffee table that's a 5x12 grid of alternating white and blue floppy disks. Maybe a row of black ones around the border, though.
