MacIP for raspberry Pi.
IlikeTech
68000
I am building a Raspberry Pi MacIP image. I have build the MacIPGW binary, and I have netatalk running, but how do I get it to connect to the software. It just says it fails to assign an address and quits when run with the peramiters on the github page.
Thanks
I guess you didn’t build a special kernel. If not ... no working macipgw.
You could grab one of my VM or ISO to test and see how it works: www.macip.net
This is probably the problem:
“Kernel
Your kernel must be configured with the CONFIG_IPDDP option disabled completely. It is not sufficient to compile it as a module -- in order to support the module, the kernel is modified to intercept all MacIP traffic, so userspace applications such as macipgw cannot handle it. “
Yep, I'm setting up a Ubuntu VM and I am going to cross compile a new kernel and isolate it from the default updater.  This should hopefully fix the problem!
Great. Could you share your image? I have a Raspberry lying around and love to make a MacIPPi for it. Your image would same me some time!
Yep, I'm in the process of writing the required systemd scripts to start things on boot time. The cool part is that you can access the netatalk share from both the AppleTalk port and the wifi connection over ip! You just connect the Ethernet port through you bridge to the Mac, and enter your wifi credentials on the sd card, and you can copy on files with your modern Mac, and then access them on your vintage one!
I probably won't be able to upload it until Monday because my internet at home is actual garbage. I'll use my connection at school! When you boot the image, you need to expand the file system using raspi config.
Hello
I am not an expert
Does MacIP run in a PI3 ?
in that case could you tell me where I can found an image file ?
I have tried the drive.google.com link and have installed the file in my Pi3
I had a trouble with the login / pwd
Thank you for your help !
From Boston, MA
Franck
Hello
I have installed MacIPpi in an orange pi one with the .img
but it doesn’t work
The boot is ok
after the logon : nbp_lookup : cannot assign requested address
I can’t see the network
my config
mac duo 270c connected to asante by appletalk cable
asante connected by ethernet to airport extreme
orange pi one connected by ethernet to airport extreme
Could you help me ?
best regards
Franck
I reboot the mac and the orange pi one
no more error
on the pi I can see
afpserver
Ipgateway
netatalk
workstation
Ipgateway is on 172.16.2.1
but i can’t see anything in the mac :
the tcpip panel is 172.16.2.2 on localtalk
on the chooser : appleshare on but I can’t see the file servers !
regards
Franck
