TashTalk USB
Based on Tashtari's Pi Hat I've put together a USB-to-TashTalk board based on a CP2102N and a full-duplex transceiver so it works with or without a LocalTalk dongle.
The goal of this is to make it trivial to plug in and transfer files between any classic Mac with a LocalTalk port and a modern Mac/Linux/Windows machine via the software stack I've been developing here: https://68kmla.org/bb/threads/fun-with-userspace-appletalk.51616/. It should also work with any existing TashTalk software as well since it uses an unmodified TashTalk firmware.
The schematics and board files are available on GitHub here: https://github.com/FeralFirmware/TailTalk/tree/main/TashTalkUSB, along with the software I am making for it.
I have a little GUI for controlling the server now that is just about ready for trials for Linux and Mac users too. Windows will come a bit later as well. It can serve up an AFP 1.0 - 2.1 compatible file share via EtherTalk or LocalTalk via TashTalk based on a chosen folder of your machine.
I have one more board run I need to do for the final version as I had a silly mistake on this first run (It works, but required some trace cutting and bodges since I failed to check the DIN-8 pinout properly), but the first 10 I will be fixing up and handing out for people to try. Let me know if you are interested!
