The typical approach to "wobbly video" is to check for cold / weak solder joints
Given that we're also having variable voltage with draw on the PSU, I'm more inclined to suspect that.
I have tested the outputs on the FDD connector. The results are as follows;
Firstly, those are significantly too low.
Secondly, if it's struggling to provide that voltage (which we can tell because the voltage dips when more current is drawn), adjusting potentiometers will do precisely nothing meaningful, because it won't magically allow the power supply to push more juice.
You probably need someone who actually knows about switch-mode power supplies to fix this, unfortunately. Or knows more than I do at any rate.
