Need some general Digital Logic help here, gang.
None of the datasheets say whether the 04 inverts a signal going both ways. The arrow shape in the graphic tells me no and my gut tells me it must be an "understood" kinda deal that inverting a signal is a one way street? EVERY hit I get for bi-directional inverter is either another useless data sheet or worse, info on bi-directional AC/DC Inverters.
I REALLY need some help here, color me clueless/confused/concerned. :blink:
@Bolle is asleep and this one will keep me awake, so:
Those arrows look ominous and have for some time.
Here's the first bit of digital logic gibberish Bolle tossed my way:
This is Bolle's schematic in Greek as far as I'm concerned. But even after 45 years of corrosion from disuse, I'm probably still a little bit better at reading Greek than schematic.
My major concern is that we've got the LC PDS -> 030 PDS figured out, but there's either a disconnect or a wrong connection going from back to the NIC from 030 PDS -> LC PDS?
My heebiejeebies tell me we need the other three inverters on the way back to the NIC and diodes to direct the two opposing lanes of traffic? But I know next to nothing about digital logic. It looks like a bunch of pipe, valves, a whackdoodle silt collector cyclone/mixing valve thingie that needs backflow prevention valves in some mixed up section of my digitally impaired analog visual cortex. I don't think what I use for a brain will ever transition to digital. Fluidic logic I can "see" digital . . .
HELP!!!! 8-o
HELP!!!! 8-o
