Package received & I've been testing the SE/30 Direct Slot Color Pivot Cable from the Big@$$NuBus&PDScardLot™ with GREAT SUCCESS! [
It's exactly the same cable needed for macmetex's Radius IIsi Color Pivot II/PDS PassThru Cards!
Initial Test Results/First Draft of IIsi Color Pivot II Report:
_________________________________________________________________
Initial tests & second run tests done using HDD Q700 w/NO IIsi specific install done as yet . . . :/
Tests Run under OS 7.5.1
NO RadiusWare drivers installed on HDD . . . yet!
First round of tests done on expendable 21" MAG Innovision MX21F using Mac DA-19 Input
Straight thru (two cables tested) Mac Video Cable Results:
______640 x 480 x 66 Hz @ 8 Bit - 13"/14" RGB (Fixed Res Mac Monitor Standard)
Same cable with ENHANCE Liberty Dial DA-19 -> DA-19 Adapter Results:
_"J"___640 x 480 x 66 Hz @ 8 Bit - 13"/14" RGB (Fixed Res Mac Monitor Standard)
_"F"___832 x 624 x 75 Hz @ 8 Bit - 16" Color (Fixed Res Mac Monitor Standard)
Chimes of Death:
_"A"___OPEN
_"D"___1024 x 768 x_?_Hz - 19" Color (Fixed Res Mac Monitor Standard)
_"G"____640 x 480/800 x 600 x_?_Hz - VGA/SVGA
_"P"___1152 x 870 x_?_Hz - 21" Color (Fixed Res Mac Monitor Standard)
_"M"___1152 x 870 x_?_Hz - Apple 2 Page Mono (Fixed Res Mac Monitor Standard)
_"M"____640 x 480 x_?_Hz - LC VGA (Fixed Res Mac Monitor Standard)
Boots w/NO Video:
_"O"___870 x 640 x_?_Hz - Apple Portrait (Fixed Res Mac Monitor Standard)
Out of Sync/Horizontally Banded partial Image:
_"N"___512 x 384 x_?_Hz - 12" Color (Fixed Res Mac Monitor Standard)
UNTESTED:
_"H"___ PAL
_"L"___NTSC
Second round of tests done using near unobtanium Radius PrecisionView 2150
HD-15 -> 5 BNC Cable with ENHANCE Liberty Dial DA-19 -> HD-15 Adapter
_"N"___512 x 384 x_?_Hz @ 8 Bit - 12" Color (Fixed Res Mac Monitor Standard)
Stretched COLOR Video:
_"O"___640 x 870 x_?_Hz @ 8 Bit - Apple Portrait (Fixed Res Mac Monitor Standard)
Chimes of Death WITH DELAYED VIDEO & Radius Logo/No Boot:
_"A"___OPEN
_"M"__ 1152 x 870 x_?_Hz - Apple 2 Page Mono (Fixed Res Mac Monitor Standard)
UNTESTED:
_"H"___ PAL
_"L"___NTSC
I need to repeat the first run of testing on the MAG 21" CRT, as I may very well have shut down the IIsi before the Delayed Video Display appeared onscreen.
I'll test using the HD-15->5 BNC Cable with ENHANCE Liberty Dial DA-19->HD-15 Adapter on BOTH Monitors . . .
. . . just for $#1^$-n-giggles!
Adapter Free Custom Cable Pinouts/Diagrams to be posted when I have some "private time" with my continuity tester! [
The SE/30 Card has an ID conflict with the IIsi Card when used together . . .
. . . but there are jumpers on the IIsi Card to be tested! }
I'll have to find an extra SCSI HDD to load with 7.0.1/TuneUp "For any Macintosh" and load the proper RadiusWare™ Drivers to see if any or even all those Video-no-Boot situations are remedied. I don't have any specs handy . . .
. . . but we MIGHT be able to coax 19" Color outta these puppies!
I was happier'n-a-pig-in-poop when I got 16" Color @ 8 Bit on the first test-go-round! [
Pics-n-stuff to be posted later! :approve:
Chimes of Death:
_"A"___OPEN
Boots w/NO Video:
UNTESTED:
_"H"___ PAL
_"L"___NTSC
_"A"___OPEN
UNTESTED:
_"H"___ PAL
_"L"___NTSC
