This is a bit of a story but I will try and make it short. I have a 17" lcd ADC monitor. The usb/brightness keeps going out and it is a common problem, the general consensus is a bad usb hub on the main board, and a used main board with working usb ports, when I put it in Saturday it worked the first time then my girlfriend used it Sunday and it stopped working, so im sure it is the problem. So seeing as I do not want to try and get yet another one and see it fail (I am told by other forums that sometimes they will come back to life for a bit if left unplugged for a while). So I was considering installing, since it would fit, a usb hub in to the monitor and connect it to the proper pins of the adc cable. the speakers would not work in them anymore since It would not have the special 10v mode but I could care less note this picture I made of the pinouts for the two ports on the back of the monitor,
. I have found the pinouts for the adc here http://pinouts.ru/Video/apple_adc_pinout.shtml and see 3 of the usb pins but I would like to know how they are wired up in the adc to dvi adapter, so if someone has one of the off brand ones that are easily opened I would like to see how it splits off the usb for the usb port. Honestly from the pinout I do not know if this will work so that is also part of this long question. Thank you for reading this short novel!
I just added a picture with the main board and the brightness usb interface pinouts as listed on the board.
After unplugging the cables on the main board and plugging them back in the usb/brightness works again but I think it will go out again soon so I still want to rig in a usb hub to make this error never happen again.
I also used a multimeter to see what pins the eight wires from the main board go to on the adc and found the following
1. brown ground
2. yellow adc pin 19 DDC CLOCK
3. blue adc pin 9 DDC Data
4. orange adc pin 3 LED
5. red adc pin 13 soft power
6. white adc pin 22 Usb Data+
7. green adc pin 21 Usb Data-
8. black ground
so I guess I kind of answered my own question here, if I left all the wires plugged in but 6,7 and ran them to the hub with a ground wire and the 5+vdc from the labeled brightness port it should work, I would have to wire in the two ports on the back directly to the hub as well as the brightness, but I do not know what brightness wires are the usb data just the ground and +5v
1. brown ground
8. black ground
