This is interesting, and I can see that I could stand to learn a bit more about the boot process...
One limitation that I've found with the SE cards is that if you have multiple bootable partitions on a drive connected to an SE, it will only boot the first bootable partition regardless of which volume you select in the Startup Disk control panel.
