Macintosh SE Overhaul
Cawfee
Hey! So, if anyone read my previous post, I acquired a Macintosh SE and plan to recap the whole thing even if it isn't at risk on the Logic or Analog board as much as the Power Supply. A 40 year old system and having no clue if it's ever been recapped, I'm not taking any chances and end up requiring myself to buy whole new boards over installing new parts that'll add load to the unit. Anyway, I have the three sets of Capacitors I need to overhaul the Power Distribution and Charge storage, I have a BlueSCSI Desktop V2 so I can use an SD Card internally, I have the Female Molex Connectors to provide Termination power to the BlueSCSI, and I have cleaning solution (IPA) and lubricant for the dusty Floppy Disk Readers. There is a Berg to Molex Adapter, a desktop Fume Extractor, the 50-pin IDC connectors, 50-pin Ribbon Cable Spool, a Samsung 32GB PRO Endurance MicroSD Card, Fork Spade Terminal Connectors for Grounding Planes to shield the Drive and Board from EMI Fields from the CRT, and a green wire to bridge the two grounding planes on the way. I won't have everything, but I'll have the majority left of what I need on the way. Thanks for reading and have a good Day/Night depending on where in the world you're reading from!
P.S. I can respond with what I need left if anyone is curious!
Update: I cancelled the order for the grounding wire and Spade Terminals because I plan to use Copper Tape.
