Hello...
I am running a Blue & White G3 @ 400Mhz. I have 1 GB of RAM. The OS is 8.6. I am using the 5 GB mechanical hard drive that came with this computer.
I just got the B&W on line a few minutes ago. It is plugged into my ethernet network. I have about 150Mbps down load speed from my cable provider.
I went here:
http://obsolete.macfixer.com/vintage-software/
And I am down loading a file. My down load speed is between 160 and 164 KB/sec.
Is this about right for my processor? I am using the IE that came with 8.6 which is version 4.5
I will be moving to a solid state hard drive and 9.22 soon. Will this change my down load speeds very much?
thanks
mraroid
I went here:
thanks
mraroid
