Designing a portable RAM card
You could always use a i8042 to control the A20 line. ;)
Is there any benefit to mapping the full 9MB? Isn't the 68000 limited to addressing 8MB max with the typical Macintosh memory mapping?
the portable is an oddball. All RAM is mapped up until you run into ROM. Rom doesnt begin at 40 0000 as on the SE/Plus,etc. it begins at A0 0000 or 90 0000. Something like that.
Why would I use an i8042? thats a keyboard controller.
You think Apple meant for it to address that much memory, or it's just a fluke/oversight/they didn't care that it could be made to address that much?
But, if I understand correctly, your card will allow more RAM in the RAM slot than the 5 MB the GLU limits it to, correct?
c
By way of some special pass through connector in the ROM slot that breaks out the needed extra address lines? How will that be done, exactly? Or did you solve that by doing all the encoding/decoding/etc. on the card?
I will definitely be interested in one when it's ready.
...And a new back lit ribbon cable for the LCD (or a decent repair of the current one).
c
Youll see....
the address decoding and chip select is all done on the CPLD thats on the RAM card.
I carried a tap for DTACK, and address strobe/AS. that way, I can just bring those 2 wires over to the adjacent slot to get full decode.
Eagerly awaiting the test results -- and I don't even have a Portable.  I just have pent up project pressure (PUPP).  I had this project in mind for years.   It's wonderful to see it get done even if I'm not involved (other than pulling a box out of the attic).
Techknight....  I don't know if this helps but I just found an 8MB PDS RAM card in my collection!!!!!!!! This gives you the full 8MB.. It's plugged into a 5126.. I don't know if there is more if you plug it in a 5120 but I will try... Look at the pics... It says Sunland Micro Systems
Matt
Same total ram on 5126 and 5120... But curious... Could I put in the PDS ram and a regular RAM card?? Or will it just see the max of 8MB??
Matt
It's one or the other, if I'm not mistaken.
The max is 9 MB, not 8, according to the legwork that TN has done.
Yeah I had forgotten that.. duhh.. 1mb on board.. :) Could make it a 9MB I suppose.. but will only work on 5120 like that no?? Did u want me to send it to you so you can take a peek at it??
It does make me wonder why they didn't popular that last set of pads. Maybe they just thought 9 MB was a strange number?
Well I did screw up. on one thing...
The boards did ship, and they shipped DHL. Unfortunately, they uncovered some big scandal at the ShenZhen dock, which is where my package is stuck at.
Something about counterfeit money and other stuffs, causing packages to be delayed up to a month or so before it leaves the dock via DHL.
I wish i would have known this prior to ordering and shipping via DHL...
