I took a risk on a non-bootable SE/30 in the hopes it was just a dead hard drive.
Well, the hard drive works. And it came with an Ethernet card. The Sony power supply seems to be working fine, and I would imagine the screen is probably OK too.
But sadly, the logic board does not due to a battery acid exploding some time when Michael Jackson was still alive. And that thing, it caused some of the frame to rust, caused part of the interference-shield cover to get eaten away, and frankly was pretty impressive on how much evil was originally contained in that battery.
I thought to take some photos of the damages - you can see traces, metal pins and entire components gone. I did a light isopropyl alcohol (90%) wash with a brush to get the pileup off of the board, but I'm feeling a bit skeptical about either trying to do further cleanup or whether it's even worth it.
Pics for highlights - hopefully it's high enough resolution for you to enjoy the carnage and give some feedback. How much would it cost for me to send to someone who is skilled in fixing these things?
Also - I have access to an ultrasonic cleaner - I do see professional repair outfits using this to get rid of some of the horrible stuff on boards (water damage, corrosion, etc.) - I understand the caveats and of course won't even power it up because it's missing so many components anyway - but would it make sense to do that even before sending it out for further repair (or component replacement attempts)?
Close up of where the battery used to be and the aftermath:
Corresponding back-side of board - note some pins have corrosion, some seem to be black?
Some of the hell-slurry flowed down the first SIMM (with seemingly minimal damage) and seemed to pool a little in the corner
Backside of the pooled corner
