You're running mains voltage over a barrel jack?
*12V, it's a PicoATX connected to a mAcTX LC, the PicoATX derives all its voltages off of 12V DCNo, it runs off a 5V external supply.
I realize what's going on now! I'd like to apologize for assuming that you're an idiot, as only a true a idiot would.
ah that makes sense, sorry about thatI think you're thinking of someone else's rackmac build. Mine doesn't use a PicoATX or a mAcTX, it uses a pair of tracopower DC/DC converters, one to generate 12V internally from 5, and one to generate -5V. My reason for doing it this way around is to keep as much of the heat from power conversion outside the case in the power brick, since the previous rackmac case I used didn't have any ventilation. In this one, it might have made more sense to use 12V externally, but I had already built the DC/DC module for the last rackmac and it still worked, so no need to buy anything else
edit: that's why you can't see the DC/DC in any of the photos, it was still in the old rackmac until I decommissioned it today...
That'd be appreciated
Is that a bank of mikrotiks? Nice.There definitely is someone using a picoATX in one, it's just not me!
Front panel gerbers and layout files are here https://github.com/cheesestraws/lc-rackmac/tree/main/frontpanel along with an SVG of just the port holes for an LC board, in case you want to create your own variant. The switch that this fits on the front of is an HP V1910-48G, which come up pretty cheap on eBay often - as I said, I got mine for £10. Note that there's not a *huge* amount of space in this case, but there's more than enough. I hope this is useful - I'd love to see what you come up with!
And now it's installed, so one final photo: (yes, I know my cable management is crap)
Also you’re begging me to ask what the strange array of ports on the lower cheesy is.
I'm totally crashing this thread but...yeah I'm running hEX as well. Openwrt is actually really nice on them (unlike RouterOS, it supports hardware accelerated IPv6). Don't get BGP and stuff without a lot more effort than RouterOS but it's good enough for home.Yes, for home use I really like Mikrotik kit. The UI is bonkers, but it's excellent value for money, and at home I can live with the bonkers UI for the cheapness...
That's two things in there, both Pi-based - the one on the left (which is currently plugged in) is a GPS clock, the one on the right is an RTL-SDR affair which is waiting for suitable wiring to be installed for the antenna before it can be plugged in and commissioned properly. The knob in the middle is just to adjust fan speeds.
Most of us are running AppleTalk networks in 2024 so I can't throw rocks in my glass house about strange decisionsI actually run BGP quite a bit at home because I make strange decisions, so the fact the hEX can terminate those sessions without mucking about too much is one of the things I really like about them.
Just popped in to say I absolutely love this. Great work, cheesey!Some more progress photos. I've got to mount the speaker and rescue the PSU from the old rack case, and there's still some software missing on the LCBMC. But on the whole I think this is nearly finished and will be able to replace the old case before it disintegrates. Hooray.
The ZuluSCSI is on little feet at the back, which means that the SD card slot is available over the back of the case. This is something I learned the hard way from the first iteration: make it so you can get the SD card out without having to take the whole lot to bits.
