3lectr1cPPC
Hah, I thought that was a slot loader for a second before I clicked on the image.
Actually it's just wrongIt's so wrong but so right.![]()
Any pics of your ADB mod on the iMac? Would like to seeNT3.51 support has been added with release v0.05, so I had to give that a shotView attachment 76056
Damn those guys at Apple for putting it behind a screwpost! It was definitely just meant for prototyping then.I'll try to get some, but be warned, it's fairly ugly at the moment
The problem is that the port is located behind the right screwpost for the side panel, outside of the I/O opening.
So installing the port there means you physically cannot insert ADB devices, it doesn't fit behind the screwpost and you have no access to it regardless.
My current solution is to have the MiniDIN-4 port hang off four wires, and have the side panel off so it can hang out freely, but it's not what I'd want as a final solution.
Ideally I'd add a hole for the ADB port in the sidepanel, so I can fit a panelmount connector that I'd connect with DuPont connectors on the logicboard.
I could use the mezzanine slot cover, but I want to keep that open for a DB-19 connector for a floppy drive (but that's another project)
Not only is this the first NT 3.51 installation on real hardware at all to my knowledge (wanted to do it on my lombard but had issues with the new SSD i put in, waiting for a used industrial SSD to arrive from ebay), this is also the checked build which I had issues with under emulation (would always fail trying to write to HD for some reason).NT3.51 support has been added with release v0.05, so I had to give that a shotView attachment 76056
Is the slot cover wide enough to accomodate a DB-19 connector and a mini-DIN?I could use the mezzanine slot cover, but I want to keep that open for a DB-19 connector for a floppy drive (but that's another project)
Later I will try to install 3.51 alongside my working installation of 4.0.You should be able to just install NT 4 to the same partition and have a dualboot, it worked for me under emulation![]()
I wonder if the ADK would workI got this running on my G4/400 PCI Graphics with all beige accessories.
Of course, I firstly had to make an opening in the backplate and install an ADB port on the logic board, since USB support is absent. I love it! It's like the exact opposite scenario of the USB port I fitted to the Beige G3. And booting up the Yikes with an Apple Extended Keyboard I is almost as wrong as running NT4 on this thing. Almost.
It's such a bizarre experience to run NT on this machine. It takes me back to my secondary school in 1999/2000 which was full of P200s with NT4 in the computer room.
I'd love to have sound and networking support, hope that comes in a future versionIt seems to be running stable with no graphical glitches. And it is fast!
Also, hah. This is just like my SE/30:
Couple of tips for the installation on this machine:
- You do need to do the ADB port mod, sorry, it is a fiddle.
- The hard drive has to be connected to the 16.6MB/s CD-ROM IDE bus. I installed it in the Zip drive bay.
- Set the hard drive to Master, and the CD-ROM drive to Slave. Changing Master/Slave setting later on breaks the installation.
- You may get a lot of errors trying to start the installation off the NT4 CD-ROM from the ARC firmware menu. It does eventually work, it almost seems like the CD-ROM drive needs to settle. Once you get past a certain point it does run smoothly. When I got repeated read errors, shutting down the machine and then cold starting seemed to help.
AppleDesign Keyboard? Yes, it would. I started using a M0487 but got stuck during WinNT setup when it said to press page down to read the rest of the end user agreementI wonder if the ADK would work
Dualboot with 3.51 works great on my G4 upgraded B&W, a G4 on such an old OS is ridiculous haha.Not only is this the first NT 3.51 installation on real hardware at all to my knowledge (wanted to do it on my lombard but had issues with the new SSD i put in, waiting for a used industrial SSD to arrive from ebay), this is also the checked build which I had issues with under emulation (would always fail trying to write to HD for some reason).
By the way, I note that there is driver support for the Grackle PCI bus? Does that mean theoretically we could install PCI cards that have NT driver support in our G3/G4 towers and have them work? It'd be nice to add a PCI NIC and Soundcard. That'd make the OS feel very usable.
The HAL can enumerate the PCI bus fine, the main issue is that I'm not sure if the PCI interrupts are working. I tried to implement them but haven't actually checked if the implementation works yet; if it does, then the PCI IDE controller on Yosemite should work under NT (not ARC firmware), but I don't think anybody's checked yet.
