I can. The issue is the strange frequency. Most microcontrollers and processors are made today to use a evenly divisible clock frequency. I want to use the Propeller because it have built in video generation, but it works best with a 80 MHz clock (delivered via an external 5 MHz source clock and its internal PLL). Since there is an unique pixel on the video line at each clock pulse, I cannot simply read the video signal and act upon it. 0100011100000 would look like this to the Prop: 01010. Clearly not the correct pixel data. This means that I must run the prop at the 15.6672 frequency and test the video pin at each clock pulse. However, looking over the Prop's data sheet is not giving me much hope that this will work.
This reference I stumbled across says this about video generation on the Propeller:
Each cog has a hardware video generator and two special counters (CTRA and CTRB)
* Both counters have 3 special registers (CTR, FRQ, PHS)
* The basic function of the counter is to add the quantity in the FRQ register into the PHS register. When and how this is done is determined by the setting of the CTR register.
Counters can operate independently from cog CPU with clock rates (controlled by CTR, FRQ registers) from 500 kHz to 128 MHz. This done via a PLL and VCO controlled by bit PHS(31).
* CTRA is used by the video generator, when the video generator is utilized.
This implies to me that you can clock your output scan rate independent of your CPU clock rate. Assuming that PLL applies a divisor or multiplier to the crystal input rate it seems to me the only thing you'll have to do is adjust whatever sample video generation code you're using so it applies a different multiplier to compensate for your "odd" synchronous clock input.
Frankly, the Propeller would be practically unworkable if it didn't allow something like this. For instance, the example code I've seen implies that it's possible to switch from, say, NTSC to PAL video timing simply by adjusting software. If the output scan rate was somehow synchronous to the CPU clock then it seems to me it would be necessary to change a crystal to do that. (VGA vs NTSC might be possible with the same crystal, as VGA is basically 2x NTSC, but PAL throws a monkey wrench in the works.) It also looks like it's fairly trivial to use the same counters to generate oddball frequencies for, say, driving LCDs. Unless I'm missing something it seems this should be a solvable problem.
One thought I had was to use a serial in/parallel out shift register running off of the 15 MHz clock. Then all I would need to is read each output of the shift register with the Prop. This would guarantee the correct pixel data. At least I think it would...
I did suggest a shift register on the first page. ;^) If you're afraid of driving the propeller at a "strange clock" then a shift register should basically solve all your problems. According to my back of the envelope calculations you'll have to sample at *about* 2Mhz if you can grab parallel bytes instead of bits. Suddenly you can get a lot sloppier with your timing. (Ideally it would be nice if your shift register could generate an interrupt when it was time to clear it, but polling might work as well.)
