genie_mac
I finally finished recapping a IIcx which hadn't been used in years (PSU blew up as well on first start-up :O ) and it seems successful.
The problem I now have though is the graphics card. It's a Radius GS/C-M that apparently, after doing some reading, only outputs 1152x882 and is sync'ing on green. I finally managed to hack together an adapter and found a monitor (VGA multisync) that would display an image at 1152x864 @71Hz but the quality is very bad. The monitor is not running at it's native resolution obviously but it's also showing purple shadows. The monitor is actually picking up the green signal, but somehow there is a duplicate image missing the green (hence purple) that is offset by a few pixels. Is it somehow receiving two sync signals or something?
Has anyone any experience with this kind of thing or that particular adapter (summary below)? I may try building a circuit to separate hsync and vsync from the composite green pin and feed it into the appropriate VGA pins and see if that improves the situation. But that still leaves me with sync on green (which may or may not be a problem) and I can't think of a way of stripping that.
What do you think?
Also I'd really like to use my IIcx with the 12" RGB monitor so does anyone know / have a NuBus card that does 512x348?
Radius GS/C-M:
http://www.vintagemacworld.com/radius/dircolgsc.html
1152x882 72Hz, DB15 connector.
1 Ground
2 Red Signal
9 Blue Signal
11 Ground
12 Green Signal
13 Ground
What do you think?
Radius GS/C-M:
1 Ground
2 Red Signal
9 Blue Signal
11 Ground
12 Green Signal
13 Ground
