Upgrading a Centris 610 CPU
Academician
Hey guys :)
I have recently become interested in upgrading my Centris 610 to the 68040 processor after hearing that the FPU actually boosted the speed quite considerably.
I wanted to know some opinions on whether or not this switch would pull me in the right direction in terms of getting my Centris 610 to be a nice smooth running machine.
I'll mainly be using it to send disk images to my Apple IIGs, but I want to play some games on it as well so improving performance by buying something that is relatively cheap is a + for me.
So far I have been able to locate these:
CPU 1
CPU 2
CPU 3
CPU 4
CPU 5
CPU 6
CPU 7
CPU 8
CPU 9
Which of these is processors I need to upgrade my Centris 610? And more importantly which one is the most performance increase for the money I will spend.
Quadraman
CPU 1 is probably best for what you need. 2 & 3 are LC's so you won't get the FPU you're looking for with them and the rest on the list are too expensive. I bought a pair of 40mhz 040's from IC-China recently and had no problems with them. It did take about 3 weeks to arrive, though, most likely due to increased security at customs.
I also found these from same seller
http://cgi.ebay.com/Motorola-68040-Processor-XC68040RC40M-02E31F_W0QQitemZ230141098167QQihZ013QQcategoryZ4663QQtcZphotoQQcmdZViewItem
40mhz! Woo Hoo!
http://cgi.ebay.com/Motorola-68040-Processor-Xc68040RC33M-00E31F_W0QQitemZ230138994740QQihZ013QQcategoryZ4663QQtcZphotoQQcmdZViewItem
33mhz
http://cgi.ebay.com/Motorola-68040-Processor-Xc68040RC33M-02E31F_W0QQitemZ230138994704QQihZ013QQcategoryZ4663QQtcZphotoQQcmdZViewItem
Another 33mhz
You're not going to see any speed increases unless you overclock the motherboard, though. Even if you don't overclock, the higher rated chips will likely run cooler at slower speeds and probably last longer and you'll have more room to play around if you do decide to increase the clock rate one day.
Bunsen
Admin-Witchfinder-General
Depends what you mean by "speed increases"
To whit:
A 40MHz '040 in a 20MHz machine will only run at 20MHz (so save your money and buy the slower part unless you plan to OC)
But:
The FPU in the full (not LC) '040 will speed up ... stuff ... a bit ... generally.
Quadraman
To whit:
But:
Yes, that's what I meant. The FPU will speed up math intensive operations and anything that depends on them, but you won't see a speedup in the rest of the CPU functions just by slapping in a faster chip without overclocking to the higher rated speed.
ChristTrekker
Quick lesson on '040 variants, gleaned from Wikipedia:
RC is the full chip
LC lacks FPU
EC lacks FPU and MMU
As others have said, the chip can only run as fast as the mobo is clocked for. A chip rated for a higher speed will let you achieve that speed reliably, if the mobo is clocked for it.
Academician
:cool: Thanks for all the help and information guys, that model identification stuff will really help me narrow down my search to something both affordable and worth putting in the Centris for the performance gain I'm looking for.
-Academician
TylerEss
Has anyone tried swapping a 68EC040 into a Mac? The Mac IIs don't have a (real) MMU and they work just fine, you just can't run Virtual Memory.
Does anybody know anything about the 68EC040? Is it a different die without MMU/FPU, or is it just the regular 68040 die with the MMU/FPU disabled? If it's the former, it might be a better choice for extreme overclocking, due to less heat production.
Bunsen
But what Mac would you drop it into, and how? Presumably the IIs don't have ROM support for any kind of '040, and then there are the socket problems, and RAM limits
TylerEss
I'd try putting it in a 40MHz Turbo040 and see if I could get 55MHz out of it. :)
The T040 is probably the best 68040 overclocking platform becuase you don't run into problems from overclocking the main system bus, such as the famous 'black screen on Mystic above 43MHz' issue.
Alternately, the Quadra 840AV might be a good choice, because the bus is already 40MHz. LC630 comes to mind as well, because it's the newest 68040 Mac (and even has remedial 68060 support).
TylerEss
