Zhinü
I’ve got a UniMac 82D that I’m trying to turn into a Monochrome Radius Pivot cable. From what i’ve gathered, the Monochrome Radius Pivot has the sense pins of
ID1: no ground
ID2: ground
ID3: no ground
using this pinout
However, I can’t seem to find either a way to make my UniMac 82D straight through, or set to the correct sense pins. I have a Pivot card and a Macintosh IIsi (natively supported) that I can test on with the monitor.
Does anyone have the schematic or the knowledge to either do passive passthrough or setting correct sync pins?
ID1: no ground
ID2: ground
ID3: no ground
using this pinout
