The nearest corroborations of the suggestion that drives should be formatted while they are attached to the ACARD that I can find in ACARD's PCI-to-IDE ATA-133 Controller for Macintosh User’s Manual (2001) is the third statement on p6:
■ Connect 2 hard drives in the same channel, check the Master/Slave jumper.
■ For the hard drive’s Jumper setting (Master / Slave), refer to hard drive’s Manual.
■ As hard drive contain old data which might cause the Mac OS installation problems. Before installing Mac OS, the hard drive must be processed the “initialize” first.
As I interpret the Taiwanglish, this may be no more than a reminder (as are the first two statements) of prudent drive management, but not a mandatory requirement.
Elsewhere in the manual the implicit assumption is that a blank drive will be used, but the preceding seems to allow use of a drive with data of some kind already on it. However, my own experience does not accord with the suggestion that drives used with the card
must be formatted through the card. The G4 DA that I referred to above has two drives, both formatted from OS 9 with Silverlining 6.5.8—as I use Silverlining exclusively on more than 100 drives in my possession—before the ACARD was acquired and installed. Each drive already had an OS 9.2.2 and an OS 10.2.8 partition, and functioned perfectly with the ACARD.
Is it just possible that the
formatting of drives is being confused with the
updating of firmware on the ACARD? Most ATA card manufacturers insist that firmware should not be updated while attached drives are active, and preferably should be updated with drives disconnected from the card. If someone else's mileage has varied from this prescription, I cannot argue with that, but I find the suggestion that drive preparation needs attachment of the drive to the card, at the very least, odd.
Further, when my MDD DP was sulking with a blown PSU, I simply removed its drives to the DA
pro tempore so that my work could continue. The drives not only have OS 10.4.11 and 9.2.2 on them, but also the OS ROM v10.2.1 needed for OS 9.2.2 to 'see' drives of more than 128GB. Again there was no problem in simply attaching them to the 6280M.
ACARD's manual, on p4, also assures us:
The ACARD AEC-6280M is the leading Mac add-on card, supports ANSI X3T9.2 CAM ATA4/ATA5/ATA6, data transfer rate up to 133 MB/sec and meets the demand of multimedia, real time video. It’s also backward compatible with traditional ATA modes.
The ACARD AEC-6280M supports all models of PowerMac which have a PCI slot, including PowerMac 7200, G3, G4. For PowerMac older than G4, ACARD AEC-6280M can really boost the disk performance up to 100%. For PowerMac G4, ACARD AEC-6280M allows Mac to add more drives and use software RAID.
It supports the true PnP function, in Mac 8.5 and later version, there are no software driver needed for installing an Ultra ATA133/100/66/33 HDD. With the advanced function, the adapter is really user friendly. It is coexist with the on board IDE controller. ACARD AEC-6280M with on board BIOS supports system to boot from ATA HDD. ACARD AEC-6280M also supports multitasking to improve the CPU performance.
de
