Two SEs & Accessories - $300
jdcurry
Had to head out to the pharmacy so I stopped by the nearby hardware store and picked up contact solution. Sprayed the cards and let them dry. Unfortunately still displaying the same issue. 86C037BC-EA9D-491E-823D-0C95E6DEADCB.jpeg8BF5284A-F2A8-48F2-B866-7A3AB3930CBD.jpeg
jdcurry
I took the RAM back out and did a second cleaning including light Brillo scrubbing. I also sprayed in the slots as well. The result is now different, but still not resolved.
Here is a quick video:
That looks a little better!
In the words of the tellytubbies...
Again Again Again!
Might be worth spraying some on the ROM chips, SWIM and BBU while you're at it. Basically any socketed chips, and the big 14 pin molex connector, then leave it a half hour to dry.
Highlighted parts :
jdcurry
Highlighted parts :
Okay, I just sprayed them and set a timer for 30 minutes. Is there any benefit of removing the ROM chip and spraying it on its own or is it best to leave it socketed? (sorry for the newbie questions) I also sprayed and scrubbed the RAM and got a different result on the screen but still a garbled mess at the moment.
At this point, leave things in their sockets. Disturbing things is always a slight risk, so if it can be fixed without, it's better.
I don't think you're a million miles from a working machine to be honest.
The sad news is if high level tests don't find it you are going to need to go at it much more meticulously and that is going to take time.
jdcurry
The silver lining is one out of the two machines is functional at least.
jdcurry
30 minutes later after cleaning the components and I'm still having the black and white screen (while different than before) but no startup chime or any indication it will boot.
The last RAM thing to test then is to swap the RAM from the other machine. How are the two resistors set on the working board?
If that doesn't fix it, I'd remove the two ROM chips (one at a time), spray contact cleaner into the sockets, put the chips back, wait a few minutes then try again.
jdcurry
Yes, I swapped the RAM just a minute ago, and then both SEs displayed black bars and wouldn't boot. Made sure everything was marked so I was able to successfully put the RAM back in the working board and it booted just fine. It appears the resistors are set properly for 1MB of storage. It was cut on one board (the working board) (the resistor is still attached on one side and cut from the other side) and on the non-functioning board the resistor was completely removed.
The result of the non functioning board with different RAM: IMG-8486.jpg
jdcurry
I have a number of tools, but I have never removed a ROM chip. Can you provide some advice so that I can do it as safely as possible?
Thank you again for your time and patience.
jdcurry
Well, looks like I was able to extract the ROMS carefully using some dentistry tools. Sprayed them with contact cleaner and let them sit. Was able to successfully re-seat them but now I just get a black screen and nothing more. I think I'll need to look at getting some new ROM chips or possibly see if I can trade for a working SE logic board (since it appears everything else is OK)
To test the RAM from the working machine in the non-working machine, you need to make the resistors match, I.e. cut one side of the resistor and bend it away a little so it doesn't touch.
I wouldn't worry about it too much, because if you get this machine working, you'll want to upgrade to 4MB anyway. 1MB SIMMs are fairly cheap.
