You can pop the active matrix screen from a PB5300c on one and make a plain-Jane 190 into a rather nice colour 68k powerbook. I am pretty sure that the 190 cannot take advantage of the very high end and immensely expensive 800x600 screen from the 5300ce, but it can certainly take a 640x480 active matrix from one of the higher end 5300s: I did this transplant with my daughter's 190, and it is now a rather good machine to use. The 190 will take up to 40MB ram (which is not that hard to find, as ram is mostly interchangeable with the 5300 series - note the "mostly" there), it has an IDE drive, and it will accept pcmcia cards for ethernet, flash ram disks, etc. That sort of facility is almost impossible to achieve on the 5xx series, as the pcmcia module is so hard to find - and also, obviously, on all the other 68k powerbooks. The 190 powerbooks were also the very last of the 68k Macs to be manufactured, so it is a landmark model even if it is far from being a favourite.
If handled carelessly, alas, the screen has a tendency to fall apart on these machines. To guard against this, it's not a bad idea to run a piece of strong tape along the seam near the hinges as reinforcement. The keyboard is also not the greatest - but it's not the worst found on old powerbooks, either. The same kb is found on the 190, the 5300, the 3400 and the TAM.
Stock, it's not a great piece of hardware because of the poor screens. With a little tinkering, however, it can do rather nicely. The best upgrade is an active matrix screen from a 5300, then ram. It's a 33MHz 68LC040 that it has in there, after all.
