Twin PCI Riser Project for TAM, 6360, 5x00 Single Slot PowerMacs.
Trekintosh
Yeah I’ve got Illustrator, and it would probably be best to have those files so that we can be sure no measurements got wiggled in the conversion.
Trash80toHP_Mini
NIGHT STALKER
Excellent! Was just setting the Lombard back up to retrieve the development files. This'll be great, thanks so much for jumping into the fray!
Trash80toHP_Mini
NIGHT STALKER
My research notes are over on TD.
I need to take a good look to refresh my memory, but I think everything you need is there? I need to pull my cardboard prototype out to determine the modified connector setback. Then I'll update the AI file over the next couple of days. My weekend starts tonight.
Trash80toHP_Mini
NIGHT STALKER
Off today and tomorrow, so if you can note what info I have posted isn't clear enough and what you need in order of importance I'll start knocking things off that list.
Need to pull the cardboard prototype and refine the AI8/PDF files. May want to set it back a skootch more if there's clearance at the rear? The RA cables are a bit too tight up against the backplane.
Need to add Delta for Slot A to Slot B differentiation, I think I've assumed that in current illustrations, specific pinouts for Slot B needed?
Dunno, anything you can think of would be good.
If you can give me an idea of how schematics work in KiCAD I can give translation of my "Electron Plumbing Blueprints" into that form a try.
Trekintosh
Well, schematics are pretty simple. You place abstractions of the various components on the schematic, then draw lines between the pins. To make it tidier usually you run the pins into little tags called nets. They each have a unique name and just represent that all of said pins are tied together on the PCB.
I’m happy to unplumb them for you, though. I’ll actually have some bandwidth this coming weekend now that I’ve picked up the 5400s and molar.
Could you clarify what you mean by delta for slot B?
Trash80toHP_Mini
NIGHT STALKER
Been trying to get Slot_B clearly documented. You can probably figure the schematic out from This file, which I think is more akin to a KiCAD schematic than my plumbing:
  • ZZZZZZZ-ABC-710.PDF
  • PCI_TwinSlot-TAM-6360-700.PDF
  • Buzz-Lines-020-710.PDF
Trash80toHP_Mini
NIGHT STALKER
Screenshot 2025-02-28 at 17-19-21 Test_Cable_Patch-220-1.PDF.pngFor R1 and R2 values I'll have to get back to you. It's somewhere in the threads, likely over on TD. Original sketch for MechanicalDoodle shows the resistive connection setup for Init Device Select clearly. Neglected to put that detail in the AI file. Resistive connection for Slot_A is made on Logic Board.
Haven't worked out what's going on the the two capacitors for each slot yet. My proof of concept test setup only had one slot connector on a ribbon cable based riser. All four iterations were the equivalent of Slot_A electrically, so no need for capacitors. I'll work that section out ASAP.
Trash80toHP_Mini
NIGHT STALKER
Spotted what might be confusing in the ancient Buzz-Lines-020-710 diagram and in the detail pic above. Resistive connections to Init Device Select of Slot_B and Slot_C are tied to address lines on the 1:1 connections of the address bus. Ignore the "tails" pointing down toward the Logic Board, they confuse the issue I think?
Will correct for -800 series of drawings. Will be condensing info shown across the files linked above and others. Piecing together over five years worth of research/illustration here. :unsure:
The three witness lines (boxes) somehow got filled in with black in the save as .PDF step. They'll open up in a second layer in AI for fill removal. I don't have specs on the relationship between Slot_A and the edge connector. Will put digital calipers on the 6360/5x00 single slot riser to determine that ASAP.
Any more questions?
Trash80toHP_Mini
NIGHT STALKER
OK, it's Friday night in my world, so whilst partaking in adult beverages, I've pieced together the clearest diagram I can manage at this point:
All connections from edge card to Slot_A are 1:1. Reserved pins of PCI spec hijacked for nefarious purposes by Apple for additional slots are indicated as are the Resistive Connections to address lines for Init Device Select of Slots B&C.
I'll try to take a good look at the 6x00 riser to see how C1 and C2 are implemented tomorrow.
If you can let me know what the reference points for locations of slots and edge connector will be in KiCAD I'll noodle that out as well.
  • ZZZZZZZ-ABC-720.PDF
