A PC Compatibility Card (Pentium version) can be installed into both a Power Mac 7600 and a Power Mac 8500 and successfully networked and run on both the Mac side and the Windows 95 side. Here is what to do:
First, install the PC compatibility card following the included instructions. This included installing DOS, and installing the Support Software from the diskette Apple included by running a:\setup from DOS.
Next, install Windows 95, and install the Windows Support Software on that same Apple diskette, by running a:\setup from inside Windows 95.
Create a directory called C:\NWCLIENT, and copy a standard PC ODI diskette over into that directory. ( delete the 3COM device drivers). Modify the following files to include the indicated statements:
CONFIG.SYS
LASTDRIVE=Z
AUTOEXEC.BAT
PATH=C:\DOS;C:\WINDOWS;C:\NWCLIENT
LSL
C:\APPLE\MACODI
C:\WINDOWS\ODIHLP.EXE
NET.CFG
LINK DRIVER MACODI
FRAME ETHERNET_II
Notice that we the "VLM" statement in the autoexec.bat file was not included.
Once this is done, configure Windows95 to use the "Existing ODI Driver" as its Network Adapter, and configure Windows95 as usual for IPX and TCP/IP networking.
