twelvetone12
I could draft a direct USB to PhoneNet if anybody is interested!
I'm definitely interested in this, it'd be great to be able to get a modern machine on a LocalTalk network and have it look like just another PhoneNet device complete with dongle...I could draft a direct USB to PhoneNet if anybody is interested!
Hm, what would be generating the clock in this case?And then -- what if -- you used Pin 1 and 6 of a 6P6C wire to interconnect HSK so you could transfer PhoneNET at 860Kbps...
I think that any use of an external clock for LocalTalk requires a driver, unfortunately. I'd love for someone to write a minimal driver that just switches the port to use a clock on HSKi, but I lack the ability to do so myself. If such a driver existed, I could definitely take advantage of it to make a faster TashTalk, so if anyone looking thinks they could manage it...That requires a driver though
Sooo... The original idea was running AppleTalk over shielded cable, I changed to phone jacks to be like everyone else and that's a remnant that didn't get removed. It's very much an unfinished thing that never got built.is there a point to the 1 MΩ resistor and 100 nF cap if the only 'ground' in the board is the pour?
Might as well - extra drills are free!if you replace the 6P4C with a 6P6C, even if you don't connect the extra two pins, it'll help out people like me who bought a huge bag of 6P6C jacks from a surplus retailer and have no idea how to use them up. =D
I'm wondering how I might do this. I wouldn't think there would be any passive loading effect, that is, as long as the other side of the transformer is unconnected or high-Z'd, it shouldn't matter how many transformers you have on the line... right?
Well, the max DC resistance is listed on the spec sheet as 0.8 Ω, dunno if the impedance can be derived from that...If you measure the impedance of a single transformer at 230.4 and 460.8 KHz, you can divide those figures by the number of adapters connected.
You mean because the transformer might be driving the line at the same time the Mac is? Yeah, not sure... this is kind of all magic to me on some level.I don't get how feeding TXD- and TXD+ directly into a transformer is safe. Is there never DC across them?
Switching the port to use an external clock isn't difficult. Use control code serdSetMIDI or serdSetMisc or kSERDClockMIDI or kSERDMiscOptions. For the Misc control code, use serdOptionClockExternal or kOptionClockX1CTS. Since you're not doing MIDI, the Misc control code is probably more appropriate. https://developer.apple.com/library/archive/documentation/mac/pdf/Devices/Serial_Driver.pdfI think that any use of an external clock for LocalTalk requires a driver, unfortunately. I'd love for someone to write a minimal driver that just switches the port to use a clock on HSKi, but I lack the ability to do so myself. If such a driver existed, I could definitely take advantage of it to make a faster TashTalk, so if anyone looking thinks they could manage it...
Not in terms of the SCC itself, no, it's doing it at the right time in the right way so that it has the desired effect and doesn't get overridden that's difficult... this is where I wind up giving up and hope that the challenge of figuring this out interests someone else. =)Switching the port to use an external clock isn't difficult.
Farallon's docs do state that PhoneNet is lower resistance and has a floating ground compared to Apple's connector system. Despite that, you can connect the two together, but distance become limited to what Apple's cabling supports.
The transformer is typically a Coilcraft™ P104—i.e., a 1.0:1.0 turns ratio transformer with 100-1000 turns in each of windings of 20-30 gauge wire about an E-form closed loop former of cross-section about equal to a winding loop cross-section, affording a high electromagnetic inertial mass and reducing conductive line interference. The interwinding capacitance of the transformer is very low, typically 7 pF, and the voltage isolation between windings is well over 350 volts, typically 3500 V-RMS, further isolating static charges on the network. The DC resistance of each of windings is under an Ohm, preferably 0.2 Ohms maximum.
