directive0
Updates.
Hit a bit or a weirdness patch recently. Don't know if its a prevailing trend of poor luck, or the hardware. Basically as it stands;
7100/66 "Arroway" - Drydocked/awaiting new orders
I have had to remove her main drive to get the power-house 80Mhz 7100 working.
7100/80 "Hadden" - Critical Care
This guy suffered drive failure and I was forced to remove the disc containing an install of MacOS8.5.1, move back to my 80MB 8.5 drive. :disapprove:
This install is unstable (I get Address errors at boot, am able to boot in safe mode), so I have had to disable some stock extensions as the mish-mash is surely causing conflicts. There are doubles of extensions for instance; Apple Built In Ethernet, and Ethernet (Built In). Then there are things like Ethertalk 2, which I'm not even sure I NEED anymore. Can anyone tell me what the bare minimum extensions I need for network communication would be?
AppleTalk is having problems connecting to my G4 Powerbook running 10.4. It never remembers to keep Ethernet as the default Appletalk connection, but even after resetting I can no longer get my server to mount. Even when presented with the dialogue box to enter my username and password I always end up being told the that "connection was severed unexpectedly."
