danny.gonzalez.0861@gmai
My MAC SE FDHD with a DB25 BlueSCSI (No internal HDD) has always crashed at random times. Sometimes after closing an application but not always.
Well I found a way to make it crash every single time, no if ands or buts. If I try and Initialize a floppy it will format the floppy to the point where it is getting ready to verify the image and that is where I get a crash every single time. I tried OS 6.0.8 and 7.1, both exhibit the same issue. Here is the first error it shows:
From there if I move the mouse to click restart, it starts to throw FPU and other random errors and the SE will not restart unless I use the reset button on the side.
I am using an SD from work that is a WD Purple, intended for IP cameras and are more tolerant to R/W. I have a cheapo Chinese 8GB card and it exhibits the same issue.
Multiple floppies were tried and all do the exact same thing. What am I missing here? If I format the floppy in my IIci and put data on it the floppy drive reads the data just fine and I can even play games directly from the drive. Admittedly I have not cleaned the drive thoroughly but before I take it apart again I wanted to see if you guys had experienced a similar issue and while she is apart, I can kill two birds with one stone.
As always you all are amazing and I want to thank you before hand for any help you may be able to provide.
