uniserver
who wants to pay $150 for a nic that works in the SE/30… Naaaaaaaaaaaaaaa! Boooooooooooooooooo!
who whats to pay $9.99 for a LC NIC and install it into the SE/30 Yaaaaaaaaaaaaaayyyyyyyyyy!
Techknight might have the ideas/knowledge to make this happen !
http://www.ebay.com/itm/SuperMac-PDS-Angle-Adapter-Vintage-Apple-Mac/151011026594?_trksid=p2047675.m1985&_trkparms=aid%3D444000%26algo%3DSOI.CURRENT%26ao%3D1%26asc%3D17905%26meid%3D3560927830306836012%26pid%3D100012%26prg%3D8262%26rk%3D5%26rkt%3D5%26sd%3D151117999850%26
Postby techknight » 20 Dec 2013, 22:34
BTW, Off topic: I wonder if LC PDS ethernet cards which are still plentiful, would work in an SE/30. Technically the PDS is the same. Well not the same pinning, but same architecture.
Postby techknight » 21 Dec 2013, 00:49
Now my eyes went crosseyed, but it looks like the LC-PDS. The lower 96-pin portion of it can directly swap over to the SE/30. All the signals are the same, however the pinouts are ENTIRELY different so a remap PCB would be needed.
Only thing that i can see from a quick glance, is A28 to A30 arnt included in the lower PDS. Only the expanded PDS, whereas the SE/30 contains all address lines. Also the LC PDS contains a function code 3 (FC3) which the SE/30 doesnt have. But i dont think ethernet cards use this control pin. Also the LC only has /PDS.BG (bus grant), whereas the SE/30 has both a /PDS.BG and a /BG. No idea what impact this would have.
I believe that LC Ethernet cards, given a pinout-remap would directly swap over, They both map into Slotspace $E
Might be possible with this inexpensive adaptor card?Postby techknight » 21 Dec 2013, 16:07
Well the LC card wont go directly into the SE/30 PDS. the wiring is 110% different, However all the signals appear to be the same. So to make this work, I have to make an adapter PCB with the eurocard connectors on each end, and wiring adaptations.
