TashIO: Clone of BeeHive Technologies's ADB I/O
pfuentes69
I'd take a look at Appendix C of the ADB I/O manual, it details the ADB protocol used by the ADB I/O and should help you write a function for controlling port B.
You can find the manual here: https://web.archive.org/web/1998050...80/BeeHive/ADB_IO/Downloads/ADB_IO_manual.pdf
Thanks.
Yes, I checked that yesterday and it's where I saw that the protocol doesn't seem to support a dedicated function to set values in port B.
I checked the library in Java and I think it's just using the function to configure the ports as input/output, which allows to set the level at the same time. Most likely the Hypercard tool is doing the same.
dochilli
Does anybody of you have a working copy of the ADB_Io_Software.sit.hqx file? I am building a waspIO (Aladds) and wanted to test the function with some software. Should we copy the software to macintoshgarden?
All files from the Mac garden page should be on this thread, I uploaded them to the garden after pulling them down from archive.org's archive of the original website.
But yes, for testing just use download #1.
Some files on the original website were corrupt or missing sadly, but unless someone has an old archive of their own if the site, we'll struggle to find much else.
dochilli
My tests were successfull. With a Pascal program that measures temperatures I could read analog voltages in port B and all four channels. Many thanks to tashtari and aladds for the development of soft- and hardware.
Now I will try to develop my own Pascal program that can measure forces on a force platform.
