Hello!
I have a TAM with a strange problem: It works perfectly, boots up as expected everything is fine but only for about 6-15 reboots. After that the TAM got hung in the boot process with the little colored mac (no extension loaded at that point)
I can boot with the CD or external SCSI drive but not with the internal ATA-Drive. I tried with disk first aid, Norton Disk Doctor and every other thing but nothing solved the problem. The only solution i found was to copy the internal disk to an external disk - initialize the internal hd and copy everything back to the internal hd.
This lasts for around 6 to 15 reboots until it starts again. I also tried to renew the driver partition but this did no help either.
So what is wrong with this TAM? It does not have the original drive anymore - it was damaged - I had to replace it with a newer one.
BTW. I am looking for an ethernet-card for the comm-II-slot.
Bye,
eweri
Bye,
eweri
