System 7.1: Change Keyboard Layout?
egrath
Hi,
maybe a very noobish question - but how to change to keyboard layout on a US 7.1.1 to German? There isn't any option in the Keyboard settings:
On 6.0.8 that was only possible when a International version was installed, but i thought that this changed in 7?
Best regards,
Egon
LaPorta
You need the actual keyboard file installed in your System file. I’m sure someone here will have a German layout copy. Or, if you have access to German 7, it will likely be in there.
egrath
I can install a 7.1 in Qemu and transfer files to the real one, no matter. Can you give me a hint where the Layout is stored?
LaPorta
I’m sorry, the System file suitcase itself in the System Folder should contain the keyboard layouts.
egrath
Interestingly, on a fresh, german 7.1 the suitcase only contains a few audio files and no keyboard maps. So i assume that they are hardcoded into some binary ... if anyone happens to have a suitable german keyboard layout for 7.1 i would be glad to have it too :)
aladds
What installation options did you choose? I seem to recall that some of the more minimal selections don't include all of the layouts. They should be in the System file.
slomacuser
If the german layout is selected than it is not visible in suitcase. Select us or other layout and german will appear in a suitcase
egrath
Indeed, you are absolutely right. As soon as i select US as the keyboard on a german installation, the german layout appears in the system suitcase:
Thank you very much for your help to all! /case closed.
olePigeon
I feel like it'd be pretty handy to have all these different keyboard layouts easily downloadable.
ArmorAlley
I transfer the keyboard file from my Mac OS 9.2.2 system file to the system 7.1 system file using drag & drop in Mac OS 9.2.2.
Is there a utility like Font/DA Mover for keyboard layouts in System 6?
