Mac Plus 6.0.8 change keyboard layout
Wawavoun
Hello there !
I have a Mac Plus with a french layout keyboard.
I have made my own boot floppy disk with Minimal Mac Plus 6.0.8 system (no network, no printer etc...).
Now what should I add to this boot disk so I can change the keyboard layout from us to french ?
I have the Macpack disk image which has a 'keyboard ' control panel application in 6.0.8 folder but dont know where to move it on floppy...
Regards.
Philippe
LaPorta
I believe you also need to install the keyboard layout in the System…but I’ve never done that in System 6. Someone will chime in I’m sure.
LaPorta
Very interesting. I knew how to choose the layouts in the Control Panel, but never knew how to add them to the System in System 6. Thanks!
ilio
New member
Hi, thank you all in advance for the tip. Unfortunately it did not work for me. I tried to drag the deutsche file on the file system of Mac plus hard drive after booting from floppy.. but it just does not work... it instead copy inside the folder. what am I doing wrong?
slomacuser
You can use this
Wawavoun
Hi,
You know the difference between a FILE and a FOLDER ?
You should drag and drop the layout to the FILE named "system", not into the folder.
Regards.
Philippe
ilio
New member
Hi,
Regards.
Philippe
Yes, I know... but thanks for asking again.. i move the layout ONTO the file named "system" but it just copies INTO the folder instead. however the approach proposed by slomacuser worked it out. thanks!
