Mac128
Since a 128K & 512K operate differently, some software doesn't work properly under a 512K. Plus I do a lot of testing between the two machines which usually involves a logicboard swap rather than dragging another Mac out. So, I've been thinking ... I have an original 128K board that has been upgraded to 512K RAM via the Larry Pina described method, not the Tom Lee method. Larry Pina says on p. 183 of Macintosh Repair and Upgrade Secrets that after installing 512K RAM, the Mac will continue to act as a 128K until the mux. decoder is installed. Since the mux. board only attaches by 5 pins at location E3 on the original 128K board, it seems like I could install a simple 5x dip switch between it and the logicboard and with the flip of a switch go back and forth between having 128K & 512K RAM.
I would appreciate anyone with more knowledge in this area to weigh in on whether this is sound reasoning, or if there is some consideration I am overlooking.
