Sony CR44 power supply repair... or not?
clh333
Been reading  http://www.ccadams.org/se/classicmac2.pdf and also Pina's books for info on repairing Mac SE power supplies.  I have a Sony CR44 that tests the -12VDC lead as -8.5, +5VDC as 5.3 (both lines) and +12VDC as 13.5 and 14.2 respectively.  I have already recapped the PSU and am reasonably confident the error is not the result of that work.  However, that's as far as I went and now I suspect that the problem lies elsewhere.
I have three choices, it seems: try further repairs on this unit; buy a (used) replacement or find a new supply to use instead.  Each of these presents its own challenges.  Pina is certain that IC 151, a Sony IK1H4, is at fault.  I can't find that part anywhere and I have no cross-reference or data-sheet for the part.  A used power supply may well have, or develop, the same problems this one has.  A new power supply will probably need to be adapted for use in the Mac, and apparently not many supply two independent +12VDC supplies.
I'd be happy to hear suggestions as to how to proceed.  Thanks for your replies.
-CH-
Johnnya101
If needed, I have a PSU that I got in my haul from an SE with no cover on it, so assuming its a parts PSU. Could swap out some stuff from that.
clh333
Thank you for the offer.  Let's see if anyone else has any ideas.  I'd really love to find that Sony chip or a replacement.  Better yet I'd love to find out why the voltages are so far off.
Thanks for your reply,
-CH-
trag
There's a thread around here somewhere about replacing the guts of the SE or SE/30 PS with the guts of a mini-ITX or 1U power supply.   If you can't nail down your component failure you might look at that solution.
Jinnai
I want to know if you find a solution. Your voltages aren't that far off: mine has between 1 and 2 volts on both 12v and 5v. I also recapped, but it didn't fix it.
